Members DavidL Posted April 10, 2015 Members Report Posted April 10, 2015 huns, when you free hand cut do you cut on the line you draw with the pen or on the outside of the line and sand it flush? Quote
Members huns Posted April 10, 2015 Author Members Report Posted April 10, 2015 huns, when you free hand cut do you cut on the line you draw with the pen or on the outside of the line and sand it flush? I did inside of the line, so I didn't need flushing. Today's works. Quote
Members Bruce H Posted April 13, 2015 Members Report Posted April 13, 2015 Wow...I would have never thought a white case could look so good. Your work is astounding! Thanks for sharing! Quote
Members BigMatt Posted April 13, 2015 Members Report Posted April 13, 2015 Great work Huns. I am a big fan. Quote https://tiekenleather.wordpress.com/
Members joesu88 Posted April 14, 2015 Members Report Posted April 14, 2015 Superb attention to details. Excellent execution. Can share your template?? Just asking Quote
Members DavidL Posted April 14, 2015 Members Report Posted April 14, 2015 huns, I have a few questions if you don't mind. When making the bag what thickness do you aim for the edge? Altogether the edge thickness looks like 5-6 mm. If edge is 3mm is this too thin of an edge for the bottom of the bag? I see the edges even for the handle are in the 5-6mm thickness is this so they do not bend? When stitching do you hit the pricking iron almost through the leather? How do you keep the back side of the stitching to look so even. I stitch a lot but can not get a completely consistent stitching all the time. Once in a while stitching will look bad for a couple of stitches or one stitch will not look good, making the project have a bad look. Quote
Members huns Posted April 22, 2015 Author Members Report Posted April 22, 2015 Finished. Thank you for watching! 15cm width. Epsom white. Quote
Members huns Posted April 22, 2015 Author Members Report Posted April 22, 2015 huns, I have a few questions if you don't mind. When making the bag what thickness do you aim for the edge? Altogether the edge thickness looks like 5-6 mm. If edge is 3mm is this too thin of an edge for the bottom of the bag? I see the edges even for the handle are in the 5-6mm thickness is this so they do not bend? When stitching do you hit the pricking iron almost through the leather? How do you keep the back side of the stitching to look so even. I stitch a lot but can not get a completely consistent stitching all the time. Once in a while stitching will look bad for a couple of stitches or one stitch will not look good, making the project have a bad look. Hello. This is 15cm widht small bag. It's around 3mm thickness. sometimes I used intension board, front and cover, and bottom. I don't know what types of leather you use, and your style. so I can't recommend best thickness for you. about stitching hole, I always use diamond awl. my pricking iron is only for marking. for good stitching hole, it need practice. Quote
