Members Rowdybarn Posted April 27, 2015 Members Report Posted April 27, 2015 I have a Consew 205rb-1 and the needle won't pick up the boo in thread? Any ideas? This is a new machine. Quote
Moderator Art Posted April 27, 2015 Moderator Report Posted April 27, 2015 I have a Consew 205rb-1 and the needle won't pick up the boo in thread? Any ideas? This is a new machine. Rowdy, Check that the needle is in correctly, groove to the left. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Members Constabulary Posted April 27, 2015 Members Report Posted April 27, 2015 (edited) Sorry Art but the grove is on the left, the scarf is on the right! But I´m sure you meant the scarf. @Rowdybarn Maybe the needle bar is a bit too high or to low or the hook tip is too far away from the needle or the needle / hook timing is off. Since it is a new machine I´m sure the manual gives you instruction how to make adjustments. If you don´t have a manual you can download it here: http://www.consew.com/Files/112347/InstructionManuals/205RB-1.PDF if you still have trouble I´m sure someone here can help you. Edited April 27, 2015 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Colt W Knight Posted April 27, 2015 Members Report Posted April 27, 2015 Does the 205 have a reset button like the 206 on the flat bed? Its a silver button you hold down, and turn the pulley to line everything up. Quote
Moderator Art Posted April 27, 2015 Moderator Report Posted April 27, 2015 Isn't that what I said? Why don't you read what I wrote before correcting me? Art Sorry Art but the grove is on the left, the scarf is on the right! But I´m sure you meant the scarf. @Rowdybarn Maybe the needle bar is a bit too high or to low or the hook tip is too far away from the needle or the needle / hook timing is off. Since it is a new machine I´m sure the manual gives you instruction how to make adjustments. If you don´t have a manual you can download it here: http://www.consew.com/Files/112347/InstructionManuals/205RB-1.PDF if you still have trouble I´m sure someone here can help you. Quote For heaven's sakes pilgrim, make yourself a strop!
Members Constabulary Posted April 28, 2015 Members Report Posted April 28, 2015 Art - I´m sure I read the grove to the right - but seems I misread and typed to fast - sorry Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
