Members vericone Posted May 17, 2015 Members Report Posted May 17, 2015 (edited) Hello, I've found a lot of information on this forum and I appreciate it a lot. But there is a thing that I can't figure out. I've found Pfaff 335 described as H3 17 1B L but the arm looks different then others I've seen. I assume that "other machines" are designed for binding and this precise one is exclusively for leather - but I'm not sure... Normally in the arm there is the dog feed mechanism... What are the differences above just the look of machine? (here are some photos of this machine) Edited May 17, 2015 by vericone Quote
Uwe Posted May 18, 2015 Report Posted May 18, 2015 I'm not really an expert on these machines, but the various subclasses on that model normally are just various combinations of base plate, presser feet, feed dog, etc. On some machines you can change a machine over from one subclass to another simply by swapping out certain parts. This particular one does not appear to be one of those. This document gives some details on the "normal" subclasses of the Pfaff 335 H3: https://www.universalsewing.com/images2/parts_lists/all/echbr8a0.pdf To me this machine does not look like what a stock Pfaff H3 17/1B "should" look like, so it may be a custom build for the Polish market or modified later in life for some custom application. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members vericone Posted May 18, 2015 Author Members Report Posted May 18, 2015 Thanks Uwe, I think so too... as this would be my first triple-feed machine, buying a custom one is not a good idea... I haven't found any info on this particular machine, so further adjustments or finding spare parts would be nightmare. I will stick to "ordinary looking" Pfaffs and Adlers Quote
Members Gregg From Keystone Sewing Posted May 18, 2015 Members Report Posted May 18, 2015 That looks like some custom work there! Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members vericone Posted May 20, 2015 Author Members Report Posted May 20, 2015 (edited) I've also found this Adler. Description of the photo says it's an "ADLER-OMAC EOS KL. 69-FA-373" ( Found here: http://www.sieck.de/en/machines/shoe-manufacturing/diverse-machines/details/1665/ ) Then doing some more research found this: http://leatherworker.net/forum/index.php?showtopic=62222 and straight to this: http://www.omacsrl.com/products/sewing-machines/with-arm/sewing-machine-with-reduced-diameter-arm-69-373-e-o-s/ So the case of Pfaff must be the same. 100% custom work. ( It was mentioned somewhere that the machine is made for sole sewing ) Edited May 20, 2015 by vericone Quote
Members billybopp Posted May 20, 2015 Members Report Posted May 20, 2015 It kinda looks like a cylinder arm machine and a post bed machine got together in a dark room somewhere and .... Bill Quote
