Members Flask Posted June 10, 2015 Members Report Posted June 10, 2015 Trying to order some buckles and belt blanks for my first project, and in the ordering I came across this: Length of Buckle End SkivingSo my question is , what the heck is this, and how long would l want it? Thanks in advance. Flask Quote
Members JRDill Posted June 11, 2015 Members Report Posted June 11, 2015 "Skiving" is the thinning of a piece of leather. Around the buckle area you want to do this so you get a nice and clean fold over on the buckle, and it's not a big, bulky open space. It also puts way less pressure on the hardware, allowing it to stay secure longer. Does that make sense? Quote
Chief31794 Posted June 11, 2015 Report Posted June 11, 2015 I use a template to lay out the buckle end, it measures 5-1/2" from the tip to the place where the folded end would be just in the skived area. So I measure 5-1/2" from the end of the buckle area and skive that distance on a bench skiver. I typically skive to about 6-7 oz thickness in the buckle area. Chief Quote
Members TomG Posted June 11, 2015 Members Report Posted June 11, 2015 I make tons of straps with buckles. From 1/2" wide for small collars, to 2+" for belts. The wider the strap, the longer the tab end that is skived. Like Chief, I have a set of templates that I use for each size strap that I can mark the rivet holes and the tang slot. 1-1/4" wide, I skive about 5-1/4. 1-1/2" wide, 5-1/2". If you are going to be using a keeper, I also tend to skive it down to about 1/2 the thickness of the strap. So, a 10oz strap gets down to about 5/6 oz. It's not critical. Wide straps might get skived down to 3/4 the thickness and so on. If you are using a very wide keeper, you might go a tad longer. Quote
Members Flask Posted June 12, 2015 Author Members Report Posted June 12, 2015 Thanks for the reply guys, all very helpful, I do appreciate it. Flask Quote
Members paprhangr Posted June 12, 2015 Members Report Posted June 12, 2015 which bench skiver are you guys using? Quote
Members BondoBobCustomSaddles Posted June 12, 2015 Members Report Posted June 12, 2015 Like Chief, I have a set of templates I made over the years that I use. They graduate in length for belts 1/2" wide up to 2" wide. That way all my belts are uniform. Bob Quote
