Members Jcparry Posted June 17, 2015 Members Report Posted June 17, 2015 (edited) Anyone have a pattern for a Taurus Judge model 4510 with 3" barrel? This would be a vertical carry. Would prefer to have the concealed carry version rather than the western - cowboy version id possible. Thanks in advance! Edited June 17, 2015 by Jcparry Quote
Members tnhomestead Posted June 27, 2015 Members Report Posted June 27, 2015 The How to Make Holsters book tandy has a concealed shoulder holster plan in it. I dont have it on digital, so I cant help past that. Good luck. Quote
Members Jcparry Posted June 27, 2015 Author Members Report Posted June 27, 2015 Thanks. Most of what I have found are either the cowboy style or, if concealed, are the horizontal rather than vertical. I will check it out though for sure. Thanks again! Quote
Members Sorefingers Posted September 16, 2015 Members Report Posted September 16, 2015 been away for a while and saw this post. not sure if you have solved the problem or not. I have not made a shoulder holster for a judge but have made several for revolvers and autos. I took a belt holster pattern I made and modified it to suit my needs. the shoulder straps were cut 7/8" wide for larger handguns and 3/4" wide for smaller ones. used 8/9 oz for each. Made a rectangular yoke for them to pass through and attached with rectangle rings then used chicago screws for adjustment. I have made vericle and horizontal rigs. if interested i can post a couple of pictures. Quote
Members LGW Posted May 10, 2017 Members Report Posted May 10, 2017 (edited) What do you want to have it for A reviler or a aoto mackie I have both. This is for a aoto mackie.With 1 strap that hooks to the belt.Back & front view for a reviler it wold be the same Edited May 10, 2017 by LGW 2 photo to menny Quote
Members LGW Posted May 10, 2017 Members Report Posted May 10, 2017 (edited) 17 minutes ago, LGW said: What do you want to have for A reviler or a aoto mackie I have both. This is for a aoto mackie.With 1 strap that hooks to the belt.Back & front view for a reviler it wold be the same Edited May 10, 2017 by LGW Quote
Members Vikefan Posted December 23, 2017 Members Report Posted December 23, 2017 I put one on here a while ago. Back around mid August. These might not be uploaded in order. My apologies. Vikefan Additional parts for holster for Taurus Judge09042017.pdf Additional parts (2) for holster for Taurus Judge09042017.pdf Holster outside for T.Judge prt109042017.pdf Holster outside for T.Judge prt209042017.pdf Holter for Taurus Judge (inside look for RH Draw09042017.pdf Quote
Members LazyDog Posted February 15, 2018 Members Report Posted February 15, 2018 Vikefan do you happen to have a pic of the finished Judge holster? Quote
Members Vikefan Posted February 15, 2018 Members Report Posted February 15, 2018 Yes, Here's the picture of the finighed holster on the person I made it for. Quote
