Members Nandy Posted June 29, 2015 Members Report Posted June 29, 2015 Seems it is possible but what parts are need to be replaced? Thanks. Quote
Members Constabulary Posted June 29, 2015 Members Report Posted June 29, 2015 In case it will work you will most likely need a complete new hook saddle an new bobbin case opener and a new hook assembly and maybe some more bits and bites + you have to disassemble parts of your machine or ask a sewing machine mechanic to do that. This will probably cost as much as a used machine with larger bobbin. I also had this idea for my Singer 111 but dropped it very soon. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted June 29, 2015 Report Posted June 29, 2015 We used to do a lot of them mainly 226R & Juki 562 that had reverse.We would charge $400.00 for parts & labor.The lower shaft has to be pulled out & take the hook saddle out & then mill it for the larger hook & put it back together.You also need to change the take-up lever to a longer one. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gregg From Keystone Sewing Posted June 29, 2015 Members Report Posted June 29, 2015 We used to do a lot of them mainly 226R & Juki 562 that had reverse.We would charge $400.00 for parts & labor.The lower shaft has to be pulled out & take the hook saddle out & then mill it for the larger hook & put it back together.You also need to change the take-up lever to a longer one. And change out the bobbin case opening lever as well, CowboyBob know that for sure as well. Not really worth doing this any more, but like said this was a thing at one point. We've had 111W155 machines with big bobbin like this. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Nandy Posted June 29, 2015 Author Members Report Posted June 29, 2015 Yup, it dont look useful. I rather just keep looking for an used machine with the larger bobbin. Not that I must get that now, but who knows... Thanks! Quote
Members jar944 Posted July 2, 2015 Members Report Posted July 2, 2015 We used to do a lot of them mainly 226R & Juki 562 that had reverse.We would charge $400.00 for parts & labor.The lower shaft has to be pulled out & take the hook saddle out & then mill it for the larger hook & put it back together.You also need to change the take-up lever to a longer one. And change out the bobbin case opening lever as well, CowboyBob know that for sure as well. Not really worth doing this any more, but like said this was a thing at one point. We've had 111W155 machines with big bobbin like this. So does one use the 563 hook, case opener and take up lever for the 111/226/562 conversion? I ask because I have a 563-3, 111g156 and a 226r and would prefer to convert the 226 to a large bobbin. Machining is not a issue. Quote
CowboyBob Posted July 2, 2015 Report Posted July 2, 2015 Yes, those are the parts you need to change.You could just trade them from your 563 since it doesn't have reverse.You can also use the 563 hook saddle then you don't have to mill it to make it work. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gregg From Keystone Sewing Posted July 2, 2015 Members Report Posted July 2, 2015 IMHO this is more sewing history than anything; you're really best off finding a new/used machine than converting. After the labor and parts, it's just not worth it, and there is a reason nobody wants to do this kind of job any longer. It would have to be a special machine or circumstance to really want to go ahead and want to do this. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members jar944 Posted July 2, 2015 Members Report Posted July 2, 2015 Yes, those are the parts you need to change.You could just trade them from your 563 since it doesn't have reverse.You can also use the 563 hook saddle then you don't have to mill it to make it work. Great, Thanks for the info. IMHO this is more sewing history than anything; you're really best off finding a new/used machine than converting. After the labor and parts, it's just not worth it, and there is a reason nobody wants to do this kind of job any longer. It would have to be a special machine or circumstance to really want to go ahead and want to do this. In my case I only have $310 (total combined) into all three machines, and since swaping parts is free, this will be the low cost option to get the best combination of what I already have. Quote
Members Gregg From Keystone Sewing Posted July 3, 2015 Members Report Posted July 3, 2015 Great, Thanks for the info. In my case I only have $310 (total combined) into all three machines, and since swaping parts is free, this will be the low cost option to get the best combination of what I already have. Works for me, and makes perfect sense here. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
