Members dscott Posted November 5, 2015 Members Report Posted November 5, 2015 was thinking about getting some thread from Main thread Co has anyone used them pros and cons and what size is good for small projects like small cases thank you Quote
Moderator Art Posted November 5, 2015 Moderator Report Posted November 5, 2015 I use their waxed polycord. Good thread. Remember, it is waxed, so it will not take dye, so sewing is the final step, and you need to match (or contrast) the color to your project. I usually use it to sew in welts to insoles, so I can use any color. Art Quote
Members dscott Posted November 5, 2015 Author Members Report Posted November 5, 2015 (edited) Thank you i make cases for cigar cutters and lighters what size you think would work for what i make was thinking the .040 Edited November 5, 2015 by dscott Quote
Moderator Art Posted November 5, 2015 Moderator Report Posted November 5, 2015 .040" is about 1mm, .035" is about .9mm, and .030" is around .76mm. .040" is pretty big, .035 is still large, but seems to fit a lot of the stitching punches out there, but so does .030. It really depends on the size of the hole, the type of hole (diamond or /) and the spacing. Generally, if the size isn't way out of line, you can make it work. Art Quote
Members dscott Posted November 5, 2015 Author Members Report Posted November 5, 2015 (edited) thank you i use 1/8' diamond spacing still using the tandy ones i need to upgrade any suggestions Edited November 5, 2015 by dscott Quote
Moderator Art Posted November 5, 2015 Moderator Report Posted November 5, 2015 Seiwa 2 and 6 prong #3 for 8 spi with .030" or maybe .035" thread, Irons from GoodsJapan, thread from Maine Thread. The irons go in and out of stock a lot so have them email you when they are in stock. They are well made and heat treated, as with all this kind of iron, polishing on a cloth wheel with compound will help immensely with insertion and extraction of the iron. You can also polish them with a Dremel or Foredom. Art Quote
Members dscott Posted November 5, 2015 Author Members Report Posted November 5, 2015 thank you so much Quote
Members darkmatter35 Posted November 6, 2015 Members Report Posted November 6, 2015 Main Thread has a free thread color and size chart. I have one and it comes in real handy. John S. Quote
Members dscott Posted November 6, 2015 Author Members Report Posted November 6, 2015 thank you i got one ordered one yesterday Quote
Boriqua Posted November 18, 2015 Report Posted November 18, 2015 (edited) This should tell you what I think of maine thread There are a couple of other rolls in another room. I really like it. Just the right amount of wax, lays nice and flat when pulled taut and a minimum of stretch. Color stays nice and true. I am actually working on another order. Get the free sample card and enjoy! Edited November 18, 2015 by Boriqua Quote
Members JamesR Posted November 22, 2015 Members Report Posted November 22, 2015 I use Maine thread/cord all the time. I call them so I can purchase larger spools then what you see on the website. Quote
Members dscott Posted November 27, 2015 Author Members Report Posted November 27, 2015 thank you all so much sorry late riply Quote
