llucas,
Call Allen Weaver. He can walk you thru it just like he has on other things.
glenn
Next on my list. Thanks. He is indeed a great resource.
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
After tinkering with it a little further Allen Burkholder from Weaver returned my call and walked me through it. Here is his process for the Adler 205-374:
1. Rotate wheel to bring needle about 1/16” into the feed dog. Keep the upper presser tension adjustment knob under tension; don't remove it or the spring.
2. Loosen both blocks on presser foot bar let everything drop. Snug up.
3. Rotate with handwheel to highest position for outside feet.
4. Measure outside feet – need 9mm.
5. If not 9mm, bring needle a little lower into the feed dog, loosen lower block and adjust block down and retighten accordingly until 9mm is achieved.
6. Rotate until center presser foot is at its highest point and measure. Need about 8mm there.
7. If center foot is out of measure, loosen upper block and adjust center foot by prying it with screwdriver or finger on back of foot into correct measurement. Tighten upper block while holding foot in place.
8. Cycle the machine by hand and remeasure.
Worked like a charm! Allen is a fountain of knowledge on this machine. I can now bury the needle; lift the feet clear of the leather and turn a 90 degree corner without skipping a stitch or changing the length of the stitch.
Edited by llucas
I just watched another Cobra Class 4 video on YouTube. Like the Al Bane video above, the Cobra cycles so the needle hits the leather before the center foot. Is this desirable? On my machine and other Adler 205 series videos I have seen the needle and center foot hit the leather about the same time. Is this a tomatoes/tomatos kind of thing, or does it make a difference in stitching; turning corners; etc.?
Here is the video:
I am assuming the Ader 205-370 series can be adjusted to do this (needle hitting the leather before the center foot) if it is a desirable feature.
Edited by llucas
Here is another video, this time the Cowboy CB4500. In this case (at about 3:00 on the video) the foot/needle action seems to be the same as my Adler 205-374 where the needle and foot hit the leather at about the same time. Is one adjustment better than the other? Your thoughts on the question?
I set my CB4500 so that the needle and inside foot meet the top grain at the same moment, or as close as I can get. This insures that reverse stitches will hit the same holes, or at least come close to it. It also keeps the inside foot on the grain side until the needle has fully cleared the leather on the upstroke, minimizing the forward pull from the ascending needle. Getting the lifting of the inside foot and lowering of the presser foot timed is important for maintaining predictable stitch lengths.
Posted IMHO, by Wiz
Thanks, Wiz. Very helpful. Setting my machine up with the help of Allen Burkholder from Weaver put the needle and foot hitting the leather about the same time. This also cured the problem of unequal stitching in reverse. As it is now set up, in reverse the stitches hit the same hole but I was wondering about the value of the needle hitting the leather before the foot. Great help on this forum.
I am practicing on scrap using the Beast. After the help from Allen at Weaver adjusting the feet I am doing ok on the long straight runs. Where I am still having difficulty is the 90 degree turn. Still trying to figure out the optimum location of the needle in the cycle for turning the corner or putting the machine in reverse. The videos on YouTube have helped, but the cycling of my machine is slightly, ever so slightly different.
Here is the holster experiment from above (before it was finished) that is the first thing I sewed with the Beast. Of course, in my newbie status I did not know the middle foot should lift with the needle in the leather when the lift lever or pedal is used -- that is now fixed. The strap in the holster I sewed this morning.
post-55476-0-20851100-1458066372_thumb.j
You experienced Makers will see from the strap where I am still having difficulty. In the upper left corner where I started the stitch run as the second stitch starts the knot from the bobbin is on the surface. On the right hand side of the strap I managed to turn the corner by stopping close to the corner as the needle was descending. At that point I moved the needle as close to the leather as I could with the wheel and moved the stitch length lever up and down until the needle was centered on the corner and plunged the needle using the hand wheel to slightly past bottom dead center; put the stitch lever down, lifted the feet with the lever and made the 90 degree turn; lowered the feet and continued stitching to the next corner; then, same process for the next corner. So far, so good as I stitched the next long run. When I arrived at the next corner (lower left in photo) it got away from me at the corner and the feet position would not allow me to use the stitch lever to move the needle to a better spot. So, I put the needle back into the hole (slightly), lifted the feet and turned the corner, put the feet down and stitched. This left a big loop on the bottom as I continued. Frustrating being a newbie.
On the plus side, the experimental holster using the old English Bridle conditioned up ok (after not knowing what it was and trying to wet mold it!) using Fibbing's Leather Balm And Atom Wax. It is not something good enough to offer a customer, but it is ok for personal use. The learning curve moving away from hand stitching and only using moldable unfinished veg tan continues.
Edited by llucas
Also, I gave some incorrect information here. I double checked with Allen this morning. The center foot should also be at 9mm -- not 8mm. The adjustment sequence is the same; lift height for both feed should be the same.
Edited by llucas
  • 2 weeks later...
O.k., more adjustments made and after feedback by another belt maker I changed to a 25 needle and switched to 277 on the top and 207 on the bottom. Here is a test of double layer 7 oz veg tan, free handing and practicing turning the corner. Five stitches per inch. There is some marking of the leather by the new open toe presser foot -- I plan to slightly ease and polish the edges and bottom of this foot.
Criticism/critique is welcome. What do you think of what the Beast is producing at this point? Is it ready for prime time?
Here is the bottom stitch.
Here is the top stitch.
56f48b7147956_practicestitch1.thumb.JPG.
56f48b879fcff_practicestitch3.thumb.JPG.
Edited by llucas
The above photos are not great. Here is a better angle to see stitch placement. The stitches are above the surface as the presser foot does not have a ridge to press the stitch level, but on any project I do there will be a groove/crease for the stitch line.
Again, your observations or criticisms are welcome. Is the Beast far enough along to risk sewing a belt on it? Or is it not quite ready? What adjustment would you do differently to improve the aesthetics of the stitch? It is difficult for me to judge as I prefer the look of the hand stitching I have used until now.
56f576712e2ca_stitchsample3.thumb.JPG.fb
Edited by llucas
