Members Jeannette Posted March 7, 2016 Members Report Posted March 7, 2016 I just got a Singer 29-4 shoe patcher and wonder if anyone can answer a few questions for me.Does anyone know where I can get an oil/wax bowl for it?I also need a drawer for the stand. The belt on this machine is in good shape but I thought it would be a good idea to have a back up belt. What size belt do they take? I mic-ed the leather belt at 0.185". Is that a 1/4" belt? Does anyone know what the length should be for the belt? Quote
Members shoepatcher Posted March 8, 2016 Members Report Posted March 8, 2016 Jeanette, I have a bunch of the oil bowls that screw on the top of the machine. Do you have the screw or is it missing? Send me a private email glenn Quote
Members mmike956 Posted March 18, 2016 Members Report Posted March 18, 2016 (edited) After some limited experience with my 29 I've come to the reluctant conclusion that modern equals will serve you better. The stitch length on the older machines and maybe on all of them leave something to be desired. I like mine but if I had if to do over again.....I wouldn't have bought it. I would've picked up a modern cowboy or something similar. My 31-15 and 153W102 can do anything I would've really needed. I enjoy the mechanical nature of these machines than I do their actual utility. So, I would be a fixer rather than a sewing person. I had the 29 confused with a larger model I saw in the shoe shops as a kid probably a Singer model 7 maybe? My nomenclature may be off a bit there. Anyway..,here we are. Edited March 18, 2016 by mmike956 Quote Machines in use; Singer 29K58, 154W101, 153W102, 31-15, 31-20
Moderator Wizcrafts Posted March 18, 2016 Moderator Report Posted March 18, 2016 After some limited experience with my 29 I've come to the reluctant conclusion that modern equals will serve you better. The stitch length on the older machines and maybe on all of them leave something to be desired. I like mine but if I had if to do over again.....I wouldn't have bought it. I would've picked up a modern cowboy or something similar. My 31-15 and 153W102 can do anything I would've really needed. I enjoy the mechanical nature of these machines than I do their actual utility. So, I would be a fixer rather than a sewing person. I had the 29 confused with a larger model I saw in the shoe shops as a kid probably a Singer model 7 maybe? My nomenclature may be off a bit there. Anyway..,here we are. Well equipped shoe shops would often have a pedestal mounted heavy duty Adler 30-something, or a Claes patcher, either costing about 5 or 6 thousand dollars new. They might have a small bobbin Singer patcher or two for lighter and tighter quarters work, like repairing purse straps and strap tabs, sewing close to toes in shoes, or sewing patches onto motorcycle vests. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members mmike956 Posted March 29, 2016 Members Report Posted March 29, 2016 The bell crank lever had a screw missing and I replaced it along with the roller. Now I get 9 stitches per inch but the walking foot rubs the needle bar! Quote Machines in use; Singer 29K58, 154W101, 153W102, 31-15, 31-20
Members Constabulary Posted March 29, 2016 Members Report Posted March 29, 2016 Seems you installed the gib on the wrong side. It belongs on the side with the thumb screw with the small notch on the upside - if you know what I mean. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted March 29, 2016 Members Report Posted March 29, 2016 Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted March 30, 2016 Members Report Posted March 30, 2016 Check the needle screw. It looks to big to me. I believe the correct needle set screw is a #237. It is a short screw with a fairly flat head. Generic screws can be to big in the head size. glenn Quote
Members mmike956 Posted March 31, 2016 Members Report Posted March 31, 2016 You were right! I had it backwards. Now I switched from the 50 year old Nomex T70 to 92 bonded nylon for the first time. That nylon is hard to keep on the bobbin! Top thread tension seems sensitive too. I have a few cones of the old Nomex left and I like it but when that's gone bonded nylon or polyester is all there is I guess. With nylon so springy, how well does it lock at the end of the stitch? None of my machines have a reverse feature so I either rotate the work or slacken the thread and back the work up beneath the presser foot and make about two steps with the needle.. On the 29K the foot can be rotated for a lock. Quote Machines in use; Singer 29K58, 154W101, 153W102, 31-15, 31-20
Members RussellJohn Posted November 15, 2020 Members Report Posted November 15, 2020 From the library of: Superior Sewing Machine & Supply LLC ACCESSORIES ACCESSORIES SUPPLIED WITH 29K58 AND 29K62 MACHINES No. Instruction Book 50616E Machine Screw (for fastening Machine to Stand) SS418E Machine Screw (for fastening Machine to Power Table) 82833 Machine Screw Washer for use with SS418E 29 X 4 Needles (2 each, sizes 19, 21 and 22). Quote
