Members savage_here Posted December 10, 2008 Members Report Posted December 10, 2008 The angle you hold the tool at is what determines the depth of the cut not the amount of downward pressure applied. Greg This is obviously true as well. But, I work on a lot of chrome tan and softer leathers, some with texture. I can tell you that on softer stuff, downward pressure does indeed play a role, especially when dealing with a tumbled texture or the like. Quote
Members badger Posted December 23, 2008 Members Report Posted December 23, 2008 I just bought one, arrived today...... Anybody want my old ones? Seriously, this is THE best grooving tool I've ever used. I order all three size blades with it and you can colour me impressed. This tool is going to make me look great! I found you can set the depth of the groove by varying the amount of the blade stem you insert into the tool body. If the guide rod is running on your stone slab, it can only cut to a given depth. The tooled groove is laser sharp and clean. Wow! Cheers, Karl Quote
Members Geoff Posted December 24, 2008 Members Report Posted December 24, 2008 Is it possible to sharpen these groovers if they become dull? If so, how is it done? Thanks Quote
Members badger Posted December 24, 2008 Members Report Posted December 24, 2008 I plan to strop and polish the rounded outside part and run a rouged thread through the hole. They come pretty sharp and well polished. Karl Quote
Members steveh Posted December 24, 2008 Members Report Posted December 24, 2008 It helps if you moisten the leather you intend to groove, it is much easier to do and extends the sharpness of the cutting tip. Quote
Members Rawhide Posted December 24, 2008 Members Report Posted December 24, 2008 Is it possible to sharpen these groovers if they become dull? If so, how is it done?Thanks Yes It is possible. Assuming you let it get fairly dull with no nicks in the cutter, you can use progressions of wet-dry sandpaper to bring it back, followed by stropping it. What you do is find the bevel of the cutting edge and lie it flat on a piece of 800 grit paper glued to a hard flat board. Pull the bevel along the sandpaper, away from the cutting edge and at the same time rolling the tool to cover the entire cutting edge in one stroke. do this several times on 800, then 1200, then 2000 grit. Then strop it on a rouge board with the same motions. If you keep it fairly sharp and just need to touch it up, you can get away with just stropping it, or using the 2000 grit, then strop. Good luck. Quote Marlon
Members Geoff Posted June 8, 2009 Members Report Posted June 8, 2009 I am about to order a "Versa" from Sheridan. Do I need all 3 groover blades? What is the approximate cut for each. By the way, my main leather work is knife pouches & sheaths as well as belts. Thanks for your help. Geoff Quote
Moderator Art Posted June 8, 2009 Moderator Report Posted June 8, 2009 Hi Geoff, If you only do one size thread, probably not. If you do drastically different sizes like 346 and 138 then probably yes. Ask Vandy what size fits what thread and get what you need. Art I am about to order a "Versa" from Sheridan. Do I need all 3 groover blades?What is the approximate cut for each. By the way, my main leather work is knife pouches & sheaths as well as belts. Thanks for your help. Geoff Quote For heaven's sakes pilgrim, make yourself a strop!
hidepounder Posted June 8, 2009 Report Posted June 8, 2009 If memory serves me (and I can't count on it anymore), Bob makes three sizes. I use a #1 and a #2. I use a #1 for 69-138 thread. The #2 is good for up to around 277 thread. I have used it with 346 as well...but that was probably pushing it.... Bob Quote
Members Geoff Posted June 9, 2009 Members Report Posted June 9, 2009 If memory serves me (and I can't count on it anymore), Bob makes three sizes. I use a #1 and a #2. I use a #1 for 69-138 thread. The #2 is good for up to around 277 thread. I have used it with 346 as well...but that was probably pushing it....Bob Thanks for your help. I am mainly working with linen thread, with their strange count descriptions (18/3 & 25/6etc.) I am not familiar with the thread descriptions that you mention. However, I reckon that the minimum diameter is 0.5mm and the maximum diameter is 1.0mm. Regards, Geoff Quote
