I know t135 is best and that is what I have. I just meant I would like a machine that uses t207 and larger for holsters. It seems like that is going to be a pipe dream anyway. I think I can shorten the 41 tooth belt with enough strength to work. We will see.
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
If there is only one place left with the belts, I would buy two if i were you.
"If nobody shares what they know, we will eventually all know nothing."
"There is no adventure in letting fear and common sense be your guide"
They only have one left in stock and the cost would be 50.00 or more before it got here. If the cut and splice doesn't work I will send the machine to the scrap yard or part it out. I really don't see any value in the parts. If the splice works I will send a photo if not I really thank all of you for advice and will forget the 153W101. I still would like to know why this machine was converted to a wheel foot in place of the walking foot. What was the wheel foot used for? What are the advantages or cons etc? Just curious.
153w timing belts:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.XSINGER+153W+TIMING+BELT.TRS0&_nkw=SINGER+153W+TIMING+BELT&_sacat=0
EDIT:
sorry - I juts noticed the 38 teeth issue so forget the lin
Edited by Constabulary
I have a Singer Parts Catalog from 1973/74 and it lists a neoprene timing belt for the 153K101 with parts number 265715.
Usually the W and K models are the same but I can´t promise.
Google throws out this:
http://camatron.com/product/tmining-belt-for-singer-153w101-use-265715/
Hope this helps ;)
post-31854-0-62206700-1456429878_thumb.j
Those old link and cloth drive belts are sometimes salvaged from machines bought at factory auctions. Check with Gregg at Keystone Sewing or Bob Kovar at Toledo Industrial Sewing Machines. One of them may have a 153w101 carcass with a decent belt they can pull and sell to you.
Posted IMHO, by Wiz
I just tried Camatron in New Jersey who had the correct number belt but the wrong tooth count. Thanks for looking for me. I am going to call Toledo now.
Try to find out the exact length of the belt for your machine. If it has the same total circumference as a 41 tooth belt, it should fit on the cogs.
Posted IMHO, by Wiz
