Members ChapinLeather Posted January 9, 2016 Members Report Posted January 9, 2016 Would really appreciate some help in resolving a problem that I've been having with my Cobra 4 stitcher. I know I probably am not using the right words to describe a problem that I'm having but my bobbin hook doesn't line up with my needle as the needle starts to come back up and I'm having a problem with skipped stitches. My hook isn't lined up and I don't know how to move it into the right position. The bar holding the needle is in the right place when it is in full up position, but the hook on the bobbin assembly isn't and I can't move it either... so that is my question how do I line the bobbin hook up so that the timing of the bobbin is correct. I am just trying to get it into proper position to correct the stitching problem Thanks Debbie Quote
Contributing Member JLSleather Posted January 9, 2016 Contributing Member Report Posted January 9, 2016 Did you call those people? I think that's what you paid for ... the 'support after the sale'. Top of the page says 866 962 9880, so I assume that's still correct. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Moderator Art Posted January 9, 2016 Moderator Report Posted January 9, 2016 You might also try 1-909-800-1429. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Uwe Posted January 10, 2016 Report Posted January 10, 2016 (edited) The Juki TSC-441 Service Manual describes how to adjust this class of machine (Needle-to-hook/shuttle distance adjustment is on page 4&5). Depending on how faithful the Cobra 4 clone really is to the original, it may be helpful. Edited January 10, 2016 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members ChapinLeather Posted January 10, 2016 Author Members Report Posted January 10, 2016 Thanks Guys, I've contacted a couple of people but apparently I'm not able to describe what the problem is. Thanks Uwe, at least I can know what the parts are called, isn't exactly what I thought I was trying to do but I'll try looking at it awhile see if I can understand how to adjust things. A good part of the problem with fixing without illustrations or a video is the lingo, I'm not fluent in machinery, so I don't know how to describe what I'm seeing. I tried to put a video together but it bounced all around so I'm not sure it would be much assistance in determining the problem. I'll keep trying. On 1/10/2016 at 4:41 PM, Uwe said: The Juki TSC-441 Service Manual describes how to adjust this class of machine (Needle-to-hook/shuttle distance adjustment is on page 4&5). Depending on how faithful the Cobra 4 clone really is to the original, it may be helpful. Quote
Members ChapinLeather Posted January 10, 2016 Author Members Report Posted January 10, 2016 I think it is needle to shuttle timing like I thought, I have to look at it some more and see if I can figure out where the hook driving shaft crank screw is located and if I have the right set screws, then I guess it will either work or it won't. crossing fingers. Quote
Uwe Posted January 10, 2016 Report Posted January 10, 2016 So do the diagrams and illustrations in the Juki manual correspond to what your Cobra 4 looks like? Going through the manual in sequence and comparing your Cobra 4's adjustments with what they should be should tell you what is off, how to adjust it, and where the set screws are. It's one of the best service manuals I've come across. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Moderator Wizcrafts Posted January 10, 2016 Moderator Report Posted January 10, 2016 On 1/9/2016 at 5:46 PM, ChapinLeather said: Would really appreciate some help in resolving a problem that I've been having with my Cobra 4 stitcher. I know I probably am not using the right words to describe a problem that I'm having but my bobbin hook doesn't line up with my needle as the needle starts to come back up and I'm having a problem with skipped stitches. My hook isn't lined up and I don't know how to move it into the right position. The bar holding the needle is in the right place when it is in full up position, but the hook on the bobbin assembly isn't and I can't move it either... so that is my question how do I line the bobbin hook up so that the timing of the bobbin is correct. I am just trying to get it into proper position to correct the stitching problem Thanks Debbie Debbie, I can help you fix this. First, find the metric hex drive wrenches that came with your Cobra 4. You will need the largest hex wrench in the tool set for this. Proceed as follows. Turn off the power switch to the motor. Unthread the needle. Remove the bobbin cover plate so you can see the bobbin case and hook. Set the stitch length/direction lever to the zero feed position. You can verify this by placing a piece of leather under the feet and hand wheeling a hole in the leather while adjusting the lever, until the needle goes into the same hole without moving the leather.. There is a removable round cover plate on the lower right front of the machine. Unscrew and remove it. Keep the screws in a safe place. Slowly rotate the hand wheel toward you from the top down, anti-clockwise, while peering into the now open hole. You will see a clamp on a shaft that exposes a large hex bolt head as you rotate the wheel. That bolt clamps the shuttle driver shaft in place. Your goal here is to watch the hook as it approaches the rising needle's eye then move the hook into the correct position above the eye. This is done by loosening the big bolt and moving the shuttle by hand. When the needle has moved up between 1/8 to 3/16ths of an inch from bottom dead center, the hook should intersect the center line of the needle, about 1/8" above the top of the eye. You can move the hook by loosening that big hex head bolt inside the right front of the machine, which allows you to move the hook by hand pressure. That bolt will probably be very hard to turn initially. You can employ a vise grip on the hex wrench to add turning power to loosen it. Most likely, the bolt head won't line up with the opening in the body at the right point in rotation to time the hook. That would be too easy. So, I usually loosen the bolt, then apply the slightest pressure to tighten it just enough to hold its position until I move it by hand. You can do the same thing. Once you have re-positioned the hook to intersect the prescribed distance above the eye, as the needle ascends, tighten down the big bolt as tight as you can get it. Re-thread the needle and try sewing in forward and reverse. If the stitches are perfect and don't skip any more, tighten down the big bolt with the vise grip and replace the cover plate. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members ChapinLeather Posted January 10, 2016 Author Members Report Posted January 10, 2016 On 1/10/2016 at 6:47 PM, Uwe said: So do the diagrams and illustrations in the Juki manual correspond to what your Cobra 4 looks like? Going through the manual in sequence and comparing your Cobra 4's adjustments with what they should be should tell you what is off, how to adjust it, and where the set screws are. It's one of the best service manuals I've come across. Thanks Uwe yes I think it is pretty close I did manage to locate the hook driving shaft crank screw and so now I'm looking for the hex wrench size I also have to locate a regular wrench since I have a good bit of arthritis in my hands so it is hard to get much muscle behind the thing. getting there but I believe it will work, hope so. Quote
Members ChapinLeather Posted January 10, 2016 Author Members Report Posted January 10, 2016 On 1/10/2016 at 6:49 PM, Wizcrafts said: Debbie, I can help you fix this. First, find the metric hex drive wrenches that came with your Cobra 4. You will need the largest hex wrench in the tool set for this. Proceed as follows. Turn off the power switch to the motor. Unthread the needle. Remove the bobbin cover plate so you can see the bobbin case and hook. Set the stitch length/direction lever to the zero feed position. You can verify this by placing a piece of leather under the feet and hand wheeling a hole in the leather while adjusting the lever, until the needle goes into the same hole without moving the leather.. There is a removable round cover plate on the lower right front of the machine. Unscrew and remove it. Keep the screws in a safe place. Slowly rotate the hand wheel toward you from the top down, anti-clockwise, while peering into the now open hole. You will see a clamp on a shaft that exposes a large hex bolt head as you rotate the wheel. That bolt clamps the shuttle driver shaft in place. Your goal here is to watch the hook as it approaches the rising needle's eye then move the hook into the correct position above the eye. This is done by loosening the big bolt and moving the shuttle by hand. When the needle has moved up between 1/8 to 3/16ths of an inch from bottom dead center, the hook should intersect the center line of the needle, about 1/8" above the top of the eye. You can move the hook by loosening that big hex head bolt inside the right front of the machine, which allows you to move the hook by hand pressure. That bolt will probably be very hard to turn initially. You can employ a vise grip on the hex wrench to add turning power to loosen it. Most likely, the bolt head won't line up with the opening in the body at the right point in rotation to time the hook. That would be too easy. So, I usually loosen the bolt, then apply the slightest pressure to tighten it just enough to hold its position until I move it by hand. You can do the same thing. Once you have re-positioned the hook to intersect the prescribed distance above the eye, as the needle ascends, tighten down the big bolt as tight as you can get it. Re-thread the needle and try sewing in forward and reverse. If the stitches are perfect and don't skip any more, tighten down the big bolt with the vise grip and replace the cover plate. Thanks, I'm about midway down the list and have located the hex wrench... thanks I'll print this out with and attach them to the illustrated manual pages. gonna give it a try. Quote
Members ChapinLeather Posted January 10, 2016 Author Members Report Posted January 10, 2016 Is it possible to use a liquid wrench on that screw? I can't budge it, and I think I wore off a little bit of the hex wrench at least I hear a snap but the bolt still doesn't move. I'd have to get some I don't think I have any hanging around. Quote
Moderator Wizcrafts Posted January 11, 2016 Moderator Report Posted January 11, 2016 On 1/10/2016 at 8:01 PM, ChapinLeather said: Is it possible to use a liquid wrench on that screw? I can't budge it, and I think I wore off a little bit of the hex wrench at least I hear a snap but the bolt still doesn't move. I'd have to get some I don't think I have any hanging around. How close it the tip of the hook to the center line of the needle, when the needle has lifted at least 1/8 to 3/16 inch from BDC? If it is within 1/16 inch, adjust the height of the needle bar instead. Just make sure that the hook is above the eye in order for it to pick off the thread loop. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted January 11, 2016 Moderator Report Posted January 11, 2016 If you choose to lower the needle to meet the hook, make sure the tip of the needle doesn't hit the shuttle or bobbin case! If you have to lower it that far, stop and get somebody with better tools to loosen the clamping bolt as per my original checklist. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members ChapinLeather Posted January 11, 2016 Author Members Report Posted January 11, 2016 On 1/11/2016 at 1:55 AM, Wizcrafts said: How close it the tip of the hook to the center line of the needle, when the needle has lifted at least 1/8 to 3/16 inch from BDC? If it is within 1/16 inch, adjust the height of the needle bar instead. Just make sure that the hook is above the eye in order for it to pick off the thread loop. ok will look at that today and see. thanks Quote
