Members TinkerTailor Posted January 19, 2016 Members Report Posted January 19, 2016 Posted this in the other thread, so i will repost here. The tandy one that looks like a wood plane is garbage. You need to modify it and shim it to get good results. The wood handled ones are better. The craftool pro groover is the one I would buy if I bought it from tandy. The grooving blade is on the end of the tool, not hanging off the side. I found the blade on the side of the cheaper ones a little weird feeling when most every tool has the bit centered with the handle. It was also harder to control depth. The Craftool pro can be used without the guide for off edge stitch lines, or "Inland highways" . Copies(or the exact same items) are available cheaper on ebay and a few other places online for all the groovers tandy sells. If you have a few more bucks to spend, The osborne 34 scratch compass with the groover tips is the way to go. It comes with 3 groove sizes and a point. It is usable as a divider and a pencil compass as well. You can also put a stitch line further away from the edge with it. It is a really versatile shop tool. I have a quarter with a small divot in the center i put on the top of the leather with a magnet underneath and can draw curves right on the hide..... You can put a pencil in it for pattern making and drawing. It is also great for woodwork/metalwork layout duty as well. Its not cheap but is worth it. I have an antique set of starrett 92 dividers from 1910 or so and they are built exactly the same as the 34, with a minor difference in the adjuster. This is a tool to last unlike a new craftool is. One place to get it: http://www.zackwhite.com/Osborne-Scratch-Compass_p_876.html Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members billybopp Posted January 19, 2016 Members Report Posted January 19, 2016 That quarter and magnet idea is brilliant, TT. I'm gonna have to try that! I also second your thoughts on the Tandy groover. I bought one of those after trying the other type that came as part of a kit and found it awkward. It is much more intuitive to have the cutting edge in line with the tool handle. Needless to say, whatever type you use has to be very sharp, which takes some work. Bill Quote
Members Red Cent Posted January 20, 2016 Members Report Posted January 20, 2016 I use this a lot. I use the creaser and not the ditch maker. The creaser does not create a contrasting line on dyed leather and the creaser will lay down a smooth line that will swallow up the thread from my Cobra 4. Besides, you get all that other stuff.http://www.ebay.com/itm/1Set-5-in1-Pro-Adjustable-Leathercraft-Stitching-and-Groover-Crease-Leather-Tool-/361308274997 Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members memheli Posted January 26, 2016 Author Members Report Posted January 26, 2016 I appreciate everyones feedback here. Really helpful in getting started. Thanks again! Quote
Members byggyns Posted January 26, 2016 Members Report Posted January 26, 2016 I use he Tandy Pro groover with the blade in the center and guide that hangs out on the side. When I thought it was too dull, I sharpened mine a little with an extra fine stone, then stropped it to polish the edge. There's a video on YouTube that shows how to set up a strop for groovers. It is really easy to use, but I always screw up at least one small spot on a curve and let the groove get a little too close to the edge. Whenever you change direction, you have to slow down and keep that guide on the edge of the leather. Taking the guide off and using it freehand works well for stitch lines on the holsters I've made. Quote
electrathon Posted January 26, 2016 Report Posted January 26, 2016 The badmouthing of the Tandy grovers relates to the blades that were coming in them. The trouble was with the cutting edge, not the grover itself. Not sure if they have sold all the bad ones yet and got another batch or not. That being said, I do quite a bit of sewing and I never grove. The strongest part of the leather is the outer part, I have never understood why people feel that cutting off the strongest part will make their sewing stronger. Quote
Members snubbyfan Posted January 27, 2016 Members Report Posted January 27, 2016 Aesthetics, setting a stitch line down in a groove just looks "tidy." That being said, there's not a single stitch groove anywhere on my own personal belt and holster. Sometimes I'll groove, sometimes I won't, depends on the look I want. Quote Keep on Chooglin'Check out my YouTube Channel, comment and subscribe for updateshttps://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
