Members tardis86 Posted February 13, 2016 Members Report Posted February 13, 2016 so im working on a basic knife case and as i went to bend the piece over to sew it, the leather started to crack on the edge a bit.. Anyone else ever experience this issue? how can i prevent that in the future? thanks Quote
Troy I Posted February 13, 2016 Report Posted February 13, 2016 Try butting a light coat of neatsfoot oil on the leather before bending it...also if you lightly wet the leather before bending it will not be as prone to cracking. Quote TroyImler's LeatherBentonville, VA 22610 http://www.ebay.com/usr/imlers_leather
Members tardis86 Posted February 13, 2016 Author Members Report Posted February 13, 2016 On 2/13/2016 at 2:00 AM, Troy I said: Try butting a light coat of neatsfoot oil on the leather before bending it...also if you lightly wet the leather before bending it will not be as prone to cracking. i dont have neatsfoot oil at the moment, so water for now i guess. When i do get some though, should that be applied before or after any dye i use? Quote
Troy I Posted February 13, 2016 Report Posted February 13, 2016 I apply the oil after dyeing. Quote TroyImler's LeatherBentonville, VA 22610 http://www.ebay.com/usr/imlers_leather
NVLeatherWorx Posted February 13, 2016 Report Posted February 13, 2016 You can really apply the oil before or after, your choice. When wetting the leather at a fold location be sure to wet the BACK side of the leather (the flesh side) so as not to cause the dye/finish to discolor (and it will happen, especially if you use any of the water based products). Treat it just like the casing process: dampen the leather, let it sit for a few minutes until it looks like it is starting to return to normal color (but you should be able to still feel some dampness to the touch) then carefully fold your lines as needed. Above all, do not try to flatten it out with a mallet as you can put the fold at risk of cracking, regardless of whether or not you oiled it, and you can also bring some of the moisture out to the grain side being as you are no forcing the leather to fold. Quote Richard Hardie R. P. Hardie Leather Co. R. P. Hardie Leather Co. - OnlineR. P. Hardie Leather Co on Facebook
Members chiefjason Posted February 13, 2016 Members Report Posted February 13, 2016 I can't tell from the pic, but there are two things that can happen when you bend it. Cracking if the leather is old, dry, and stiff. More likely thought is "pull up" Where you see some of the base color through the dye. Some tanneries build pull up into leather. Sometimes you get it if the dye does not strike through or get deep into the leather. Occasionally, I'll get a crackling look if the acrylic finish does not take well or goes on too thick. If the leather gets bent a little too much the acrylic will turn a lighter color in the grain folds. That looks more like pull up to me. Quote
