I make similar boxes for cell phones, . . . magazine carriers, . . . etc.
I set the rivet by sliding a piece of lumber in the pouch, . . . then a 1/4 or 3/8 inch piece of flat stock steel, . . . one smack with a hammer, . . . rivet is set.
I can set that rivet with a hammer faster than I can even think about doing it with the setter.
Just the way I do things. . . . works for me.
May God bless,
Dwight
www.dwightsgunleather.com
May God bless,
Dwight
I was going to post this exact thing when i got home to a real keyboard instead of my phone. Beat me to it.
It is also way faster than fiddling with chicago screws and much cheaper. To be honest i think double caps hammered flat hold way better than ones done with a setter to keep the dome.
"If nobody shares what they know, we will eventually all know nothing."
"There is no adventure in letting fear and common sense be your guide"
I like to use the hammer and dome the outside piece, . . . but inside where it will rub on a gun magazine, . . . cell phone, . . . etc. . . . I prefer them to be flat.
I've got several pieces of steel and lumber out there in the shop, . . . some specifically sized to go right into the box.
I also made a tool that uses a small paper clip, . . . I slip the rivet into it, . . . goes down into the pouch and out the hole, . . . slip in the lumber, then the steel piece, . . . pull out the tool, . . . put on the cap, . . . SMACK, . . . done.
I believe it was an M14 magazine pouch that I first did this with.
Double cap rivets are what I've just always called rivets:
May God bless,
Dwight
Tinker, what are double caps?
Double cap rivets
