A customer of mine recently bought a POS holster on Amazon. The thing was still wet and transferred dye to his hands when he pulled it out of the box! So now he wants me to make him a new one. Problem is, I have NO clue how to make this holster he wants. He offered to send the POS to me to reverse engineer a new holster, but would rather return it and get his money back. So my question is this:
Is there a pattern for this holster?
post-62762-0-17343300-1456162257_thumb.j
post-62762-0-54001300-1456162269_thumb.j
post-62762-0-34303000-1456162356_thumb.j
post-62762-0-23223000-1456162367_thumb.j
  • Replies 28
  • Created
  • Last Reply
Top Posters In This Topic
Looking at the photos I think it might not be that hard to come up with a pattern for it as long as you have either a 1911 or a mold for one. The pics you posted seem to show a excess of moisture used during the molding process and since it showed up still damp I'm surprised it still held as much detail as it shows. I like the design but there sure is a lot happening on the back panel, cross draw, ambi-left or right wear, small of back?
I have zero holster pattern making experience.
He wants all that on the back. He says he's not sure how he wants to wear it and wants all the options to get a feel for them.
The problem with the "one holster that does everything" idea is that the one holster doesn't do anything worth a damn. You and your customer would do best to get a better idea of how he wants to carry and then go from there.
What he said. I'd recommend an Inside the Waistband holster as a good all around holster. He'll be able to wear it year round and still be able to conceal a full size 1911. A strong side high ride pancake design would be a good second choice but will be harder to conceal during the summer months. Of course if your customer is dead set on what he wants then build it but I think eventually he'll want to upgrade to dedicated holsters for different methods of carry and you may find that he's not at all happy with the holster you built him. Better to get it right the first time than to have him piss away money on a holster he won't use.
Stu
I think i would run far away from that job. The holster seems easy but the customer seems to be the issue. I agree with the above comments. One holster to do one job. Maybe and extra set of slots so the holster can be worn on the strong side and moved over for when your sitting in the car.
If he wasn't a friend I wouldn't bother with the job. Hell, if my husband didn't have a 1911 I could work with on this holster I wouldn't bother with it.
I take it there's no pattern out there similar to what I'm looking for? Even without the insane number of slots on the back? Or anything remotely close to it that I can show him? Everyone tells me to do this or this or this, but I don't even know where to begin on a holster, so none of these tips, while greatly appreciated, are helping me. I need a base, a template or pattern. Somewhere to start.
Indidana,
With all due respect there is more to building a holster then knowing how to cut, stamp, carve, dye and sew leather. If you don't know anything about holsters it's going to be pretty difficult for you to build one that works at all. The same can be said for saddles and tack, if you don't ride you have a hard time building gear that works well for its intended purpose.
That said, if you want to build a holster similar to what your friend bought I'd start with Al Stohlman's holster making book. You can get it from your local Tandy shop or it's $12.99 from Amazon. Go through the book and you'll understand how to make a holster pattern. That should get you started. Another resource you could tap into is provided by a member on this site. JLS Leather has a ton of patterns and excellent DIY info on his site. I doubt he'll have a pattern for the holster type you're wanting to make but there is enough info there to get you started.
Good luck,
Josh
Makes a fella hungry don't it, Josh... lookin at that wet noodle I mean ;)
5 leather patterns
