soccerdad Report post Posted March 15, 2016 I've read and heard that Horween Essex is not cementable. And I've also read and heard the opposite. Does anyone have direct experience gluing this leather? How does it work and hold up? If it is cementable, should I go toward or away from any particular glues? Tips? Thanks, Dale Quote Share this post Link to post Share on other sites
nrk Report post Posted March 20, 2016 check this out http://springfieldleather.com/37043/Cement%2CContact%2CLatex%2C8oz/ Quote Share this post Link to post Share on other sites
biglew Report post Posted March 21, 2016 I glue essex on a daily basis....we use a special heat activated glue.. after we glue each surface (like with contact cement) and it dries... we put them together and run them thru a heated roller press.. Quote Share this post Link to post Share on other sites
nrk Report post Posted March 21, 2016 I glue essex on a daily basis....we use a special heat activated glue.. after we glue each surface (like with contact cement) and it dries... we put them together and run them thru a heated roller press.. and the name of glue is .. ? ) Quote Share this post Link to post Share on other sites
biglew Report post Posted March 22, 2016 sorry.... it is aquagum Quote Share this post Link to post Share on other sites
soccerdad Report post Posted March 22, 2016 I've been in touch with Horween over the past few days. They say Essex is cementable, though they do not recommend any particular glues. Does anybody know how Bulldog compares to other white glues? I've been using Ever Tack with good luck. Thanks to all responders. Quote Share this post Link to post Share on other sites
Nuttish Report post Posted March 22, 2016 Essex and Dublin glue nicely with Renia Colle de Cologne. You must ensure appropriate penetration and cement your pieces within the recommended working time. Quote Share this post Link to post Share on other sites
soccerdad Report post Posted March 22, 2016 Do you use the primer? Quote Share this post Link to post Share on other sites
Matt T Report post Posted March 23, 2016 I've cemented it with Barge Quote Share this post Link to post Share on other sites
MudBugWill Report post Posted March 23, 2016 Barge, Weldwood, anything really...Essex is no different than any other leather i've found. Quote Share this post Link to post Share on other sites
