Members Tina66 Posted May 3, 2016 Members Report Posted May 3, 2016 I am new to this forum and hoping that you all can help me. I have a 29k69 that will pick up the initial bobbin thread but will not sew. I do have a manual and I have the correct needle. It seems to me that the top thread is not feeding out? Tension seems tight thru the discs but when I loosen that tension and try to sew the thread bunches up at the needle and again it wont pick up the bobbin thread to form a stitch. Help please! Quote
Contributing Member Ferg Posted May 4, 2016 Contributing Member Report Posted May 4, 2016 Are you holding the ends of both bobbin and needle thread for two or three stitches at the beginning? Check bobbin thread. With the bobbin removed, pull on the thread as it comes out from under that thin metal pressure plate. If you encounter some resistance it is good. Is the machine threaded properly? I ask, because everyone at some time let's their mind wander when threading the machine and it goes "Wonkie". Ferg Quote
Members Constabulary Posted May 4, 2016 Members Report Posted May 4, 2016 Are you sure you have threaded the hook correctly. The 29K60 is a large hook machine, rigth? So the thread has to go through the small eye at the center of the hook. I´d also check the hook timing. When the hook tip is worn you probably have to advance the hook a little bit and probably move the needle holder a bit to the right. Loosen the upper screw on the needle holder and try to move it a bit to the right. Have you insert the needle correctly long grove to the left and short grove to the right? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Tina66 Posted May 4, 2016 Author Members Report Posted May 4, 2016 Thank you both for your advice! Yes it is threaded correctly and the bobbin thread is thru the eye in the hook. There is some resistance to the boobin thread when I pull. The top thread only pulls easily when the needle is down. If the needle is up it really tugs. Yes I do hold both threads when starting to sew. I cant help but think its something simple that I just havent figured out yet. So eager to get my machine to work! I sew apparel and want to start working with leather and repairing riding boots. I so appreciate all your advice! Is there anyone close to NW PA? Quote
Members Constabulary Posted May 4, 2016 Members Report Posted May 4, 2016 (edited) Post some good detailed pictures of the threaded machine maybe someone will notice the "mistake". Have you checked the timing and tip of the hook? Edited May 4, 2016 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Tina66 Posted May 5, 2016 Author Members Report Posted May 5, 2016 Trouble posting pics says only upload 1.46mb and its only a pic... Geez Quote
Moderator Wizcrafts Posted May 5, 2016 Moderator Report Posted May 5, 2016 6 hours ago, Tina66 said: Trouble posting pics says only upload 1.46mb and its only a pic... Geez Modern cameras, especially those in the newest smartphones, take photos of many megapixels in filesize. these photos can be enlarged and printed in magazines and even on outdoor banners and signs. If you are only taking a picture for use on a web page, try reducing what is referred to as the "resolution." 800x600 pixels is a good size for web use. Forum software will reduce that to about 50% for the on-page display, then render the full size when it is clicked upon. As is, your photo is already at 931 kilobyes and just over 800 x 600 resolutiion. Otherwise, this simple close-up of your patcher shuttle, can occupy several megabytes and render at banner size. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted May 6, 2016 Members Report Posted May 6, 2016 if you are using a PC or notebook in WINDOWS OS try an image resizer: https://imageresizer.codeplex.com/ Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dave194967 Posted May 12, 2016 Members Report Posted May 12, 2016 i am also new to this forum im from adelaide south australia i have a 29k71 patching machine but i cant get it to stich i have changed the timing but each time i turn the wheel it keeps changing position i have just replaced shuttle carrier following pinion do i have to change shuttle carrier driving pinion would appreciate any advise Quote
Members Constabulary Posted May 13, 2016 Members Report Posted May 13, 2016 (edited) @ The Admin - I think its better to move Daves post to a new thread so the things do not mix up. @ Dave I would replace at least the driving pinion too if it is worn. But it could happen that new and used parts in combination bind up the gear box mechanism. You probably have to replace at least the small rack too. But this sometimes is a gamble and depends on how worn certain parts are and how well the new parts are made. The pinions usually have a flat tip teeth. Like this one: http://www.ebay.ca/itm/SINGER-29K-71-SHUTTLE-CARRIER-DRIVING-PINION-82178-/161953006221 So when they are worth they look quite sharp. Here is a sample of badly worn 29K71 pinions Edited May 13, 2016 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
