Members helena Posted June 14, 2016 Members Report Posted June 14, 2016 Going insainer I have adjusted the feed regulating spindle head thinking it somehow got locked in a bad adjustment. When I got the singer 153k 103 as it is in sweden the stitch regulator "thumb screw" was out so the numbers where to th rigth of the cut out. the groves or spiral tread that guides the set screw down pushing and locking the metal rod inplace where damaged so it could not be guided in once I got past that I can feel turning the adjusting screw how it can now pusch it out. Regardless is it safe to assume that the longest stitch 6 to the inch in this case is the feed driving eccentric bouncing off the thickest part of the rod? and if so why can I not make it feed just for a stitch by hand turning the wheel. I just wanted to sew...so I whent ahead and adjusted the feedbar with my limited/non existing knowledge about sewing machines this is maddening.som previoues clown lost a screw however the never one seem to hold the tapered gib and does not bind the tapered gibb at all. so now I am just frustrated not understanding what and how to adjust this.. this has alternating pressers in addition to compund feed so it is indeed a walking foot. Quote
Members gottaknow Posted June 14, 2016 Members Report Posted June 14, 2016 This is a common problem with the 153's. I blame a poor design and people forcing it. Anyway, you can still adjust the stitch length under the cover just to the left of the handwheel. There are two hex head bolts on a flange that you simply loosen and the two flanges move separate from the other. When the bolts are loosened slightly, you can rotate the two flanges independent from the other. Move it, thighten them back up and then test. If the stitches get smaller, move it the other direction. Don't take the small bolts all the way out. I have a picture of this somewhere, and I'll attach it to this post if I can find it. Regards, Eric Quote
CowboyBob Posted June 14, 2016 Report Posted June 14, 2016 (edited) Take out screw BB & turn CC in for longer or out for shorter. Edited June 14, 2016 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members gottaknow Posted June 14, 2016 Members Report Posted June 14, 2016 24 minutes ago, CowboyBob said: Take out screw BB & turn CC in for longer or out for shorter. Thanks Bob, I forgot about the two set screws, one on top of the other. These have to be loose to make the adjustment. If there's a broken thread where the spindle sits, you can't adjust the stitch length as it was designed. More coffee! Regards, Eric Quote
Members helena Posted June 14, 2016 Author Members Report Posted June 14, 2016 Thanks I do have been adjusting it and it does not do anything I have the same manual in paper print,Did all adjustments there is but only punching one hole with the needle...grrimageproxy (1).php Quote Quote
Members helena Posted June 14, 2016 Author Members Report Posted June 14, 2016 Ayy More coffe Eric and Cowboybob Thanks I do have been adjusting it and it does not do anything I have the same manual in paper print,Did all adjustments there is but only punching one hole with the needle...grr ! imageproxy (1).php Quote Quote
CowboyBob Posted June 14, 2016 Report Posted June 14, 2016 Try to turn screw CC out then push DD in all the way,then turn CC back down & see what happens.It won't work unless DD is pushed all the way in. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members helena Posted June 14, 2016 Author Members Report Posted June 14, 2016 The shaft will get forced out if it is in the "master" setting where you can govern it to not sew a longer stitch than desireble.If i do the same with it set to 8 leaving it hella loose or pinning it down to the rod itself the material will not feed just feet hopping on the feeddog. like there is no adjusting it that is why I was thinking that perhaps it is binding the feed fork so there is no rocking movement just up and down bouncing. I was contemplating just trying to get one adjustment but even though I can get it to be stable at say 7 any adjustment shows no forwarding movement of material or feed dog not working away from the operator just feedog going up and down. Quote
Members helena Posted June 14, 2016 Author Members Report Posted June 14, 2016 This is how it looks regardless of my adjusting Here is a movie of my trobles Quote
CowboyBob Posted June 15, 2016 Report Posted June 15, 2016 You can always take shaft DD out & get a little longer shaft & then just use the screws CC & BB to adjust the stitch length. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
