Hey guys, first post on the forum. Was hoping to get some critics and pointers on how to improve. Please take a look and let me know what you think. Any help you can provide would be great. A huge thank you to Woolfe, I studied his tutorial heavily when I got stuck.
Edited by TheITMan
Pictures didn't load
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Well done! :)
I'd pull that "wrap" around just another 1/2" or so, to get more of the trigger area covered - simple adjustment really.
If I was going to "nit pick", for myself I'd like to see that white thread with a little heavier thread and a bigger stitch length -- just for more contrast.. not structural.  I'd certainly be interested in knowing how well the black holds up on the suede side.
For a first, that looks purdy durn CLEAN.  Shoot, that looks purdy good for a tenth one :rofl:
5 leather patterns
5 minutes ago, JLSleather said:
Well done! :)
Thanks man, Iv seen some of your patterns, hope to get to that level of "clean" at some point. The trigger is in a de-cocked position right now. Normally forward another .5 inch or so. Cover the .5 your talking about?
Only thing I can't quite figure out is how to keep the edges from coming up. I sanded with 320, 400, 600, 1000 to get them smooth and get rid of the fuzzys however they still feel rough after a while. Any suggestions?
I mean half inch more to the LEFT, or other words make your reinf piece LONGER by about that long.  I don't doubt it's safe as is, just thinking like potential customers will see it.
I don't own any 1000 grit... not since i worked with oak and walnut!  I usually do 120 to get close, then burnish.  Maybe touch up with some 220 later after it's dry.  Some leather is more stubborn than others about burnishing.  I do have a little wax I use on the tough ones (roughly even mix of bees wax / paraffin).  Actually sink it INTO the leather, then buff with a piece of canvas.  The canvas will finish it up, polish it right purdy.  And I use white canvas, so if there's any coming off, I'll know .. ;)
5 leather patterns
gotcha. thanks for the illustration. ill give the wax a shot.
i manufacture custom firearms in my spare time. the 1k grit is for flat-topping and polishing the rails on my 1911's (a bit more refined than my holsters i assure you).
what length stitch do you recommend? iv just been going with whatever is on the little rolly-wheel spacer thing (please ignore my ignorance, lol) as it was cheap and i didnt have to wait for a stitching iron to space my stitches. i do want to get a set of pricking irons but not sure what size to get.... also what is the best way to finish the felt side? i put it rough out to grip the pants better when drawing but the parts that contact my side (top of each side near the loops) irritates my skin and id like to smooth that out as well. should i just use the same process as the edges? sand smooth and burnish?
Your "overstitch wheel" (I guess is what you're referring to) may have a '5' (per inch) wheel, which would be fine.  And a relatively  heavy thread.... 5-cord (ish).  Again, this is just cosmetics... I'm sure the displayed one will hold up.
And yeah, you can sand the suede, but it looks like you have a pretty good 'nap' already.
IN the tool room , back when, if I needed something that smooth it was a combination of a surface griinder and lapping compound -- neither much use on leather!
OH.. what tutorial did you see?
Edited by JLSleather
5 leather patterns
i believe this is what you were referring to when you say tutorial.
i think it did have another wheel that came with it. ill have to search, lost in the mess that is my workshop. to many gun parts to little space im afraid. gotta find a organization solution to that one.
when you say Nap i assume that refers to the texture of the leather? if so do you think i can just use some wax to burnish down the fluff? also debating finding a very thin piece of leather and covering over the tnuts.... any thoughts?
Yeah, purdy common to have a leather backer over the t-nuts.  As for finishing suede, I gotta leave that to somebody else :blush:
5 leather patterns
no worries. thanks for all your input, i try to be like a sponge and soak up as much as i can. ill post some more Pics once i get a chance to experiment some more with the holster.
That's a really good looking first holster, nice job!
Canvas as JLS suggested works well to burnish. I use cordura nylon, it works well too. You can cut up an old pair of Levi's and use them too, but the dye will rub off on your edges although on black edges that isn't a problem. Whatever you use, just make sure to wet the edge first. I use a sponge for that. then rub in one direction until it starts to gloss up a bit then rub both ways. Glycerin saddle soap, the bar, kind also works well on edges. I'll rub a notch in the bar and use it as a slicker. A little moisture then a rub down with the bar saddle soap will also usually smooth down the flesh side of your leather. Time and wear will also take care of that.
One way to have the T nuts covered is to "sandwich" them between the layers of leather instead of having them exposed on the back.
Again, nice job.
Josh
