Members Jim607 Posted August 21, 2016 Members Report Posted August 21, 2016 Any advice on splicing the drive belt on the 29K71. I have tried one but it still slips. I thought I should get some advice before I mess it up completely. Thanking all in advance, Jim King Quote
Members GPaudler Posted August 21, 2016 Members Report Posted August 21, 2016 Hi Jim, If what you have is a solid, round leather drive belt, I think that they are often just spliced with a hog ring or you can do the same with a short piece of 1/16" wire. If the belt is old and dry, you can make it a lot grippier by oiling it and wiping off the excess. If you'd like to try a new belt, check out the many types available at McMaster-Carr: http://www.mcmaster.com/#=13tqh1j Good luck, Gary Quote
Moderator Wizcrafts Posted August 21, 2016 Moderator Report Posted August 21, 2016 Try spraying some Belt No-Slip on the leather belt and the iron pulleys. You can buy it in auto parts stores. No-Slip is used on fan and air conditioner v-belts to stop squealing from slippage. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Jim607 Posted August 22, 2016 Author Members Report Posted August 22, 2016 Thanks GPAULDER AND WIZCRAFTS.. I never even considered a belt dressing but that will be my first try just to make things easy: from there I will use some of my wife wire she uses to make floral arrangements, that is plenty light. Thanks you very much for the very quick response and advise. Jim King, Elmira, NY Quote
Members Constabulary Posted August 22, 2016 Members Report Posted August 22, 2016 (edited) Depends a bit on the belt diameter a bit 8mm / 5/16" belts works best for patcher machines I´d say and maybe you can shorten it a bit if it appears to be to loose. I tried no slip spray and it became messy over the time but maybe no slip spray is different over here or depends on the brand. Be careful with oil on leather drive belts. If you take too much oil... well - it´s oil, what else can I say. Colophony is a good thing and I heard bee wax works well too but have not tried it by my self. Edited August 22, 2016 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Darren Brosowski Posted August 24, 2016 Members Report Posted August 24, 2016 Leather belts can stretch a bit over time. It needs to be pretty tight. A 29 should turn over very easily and if it is tight then there may be an issue with the machine. Quote
Members Jim607 Posted August 27, 2016 Author Members Report Posted August 27, 2016 Darren thanks for your reply. My machine turns jyst fine it's the belt that is the headache. Only have one so I thought it would be wise to ask those in the know before I ruin mine. Thanks, Jim King, Elmira, NY Quote
mikesc Posted August 27, 2016 Report Posted August 27, 2016 You can get away with ( IME it actually works better than the leather belts on treadle machines ) using the small diameter flexible plastic tube that is sold to get air into fish tanks..or is used in oxygen breathing machines or a "clear fuel line"..you don't need the type with the internal braiding, join it with a staple and melt the ends together with a lighter flame lightly applied...and it is cheap and really easy to find.. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members Jim607 Posted August 27, 2016 Author Members Report Posted August 27, 2016 Anouther great suggestion, and I just happen to have a length of it down stairs. Because I'm gone all week today is test and see day. Thanks again to everyone for your help. Jim King Quote
Members ndnchf Posted August 28, 2016 Members Report Posted August 28, 2016 Another thing to use on leather belts is rosin. I have a can of powdered rosin, it can be rubbed onto the belt to help it grip. Music supply stores sell rosin for violins too. Quote
