Tpc Report post Posted September 15, 2016 Hello from Britain, I have been making a few things with chrome tanned leather given to me by my upholsterer brother in law. Today I have bought some 1.2mm natural veg tan shoulder which I want to make a wallet with. Finishing the edges is confusing me, gum trag and burnish ok, but why use edge kote instead of the dye I used on the surface? Thank you in advance . T Quote Share this post Link to post Share on other sites
Matt S Report post Posted September 15, 2016 Forget the gum trag. Smooth your edges with fine sandpaper if it's not even, then moisten and allow to half-dry before burnishing. When burnishing apply minimal pressure and move as fast as you can. Moisten using plain water, spit, diluted PV glue, wallpaper paste or weak gum arabic solution. Quote Share this post Link to post Share on other sites
TonyRV2 Report post Posted September 15, 2016 In answer to your question about edge kote or dye, its because the edge is the most vulnerable part of the leather product. Dye will not properly protect it, edge kote however will help to seal it up so that its not prone to soaking up moisture. Quote Share this post Link to post Share on other sites
ITCL Report post Posted September 15, 2016 Hello TPC, as far as I am concerned gum trag is bad stuff. Dye will not penetrate the leather any place gum trag has been applied. I always sand my edges first. After they are smooth I apply water to the edge and rub with glycerin soap and then burnish with a burnishing tool. Or with canvas if you don't have a burnishing tool. This will give you a very smooth edge. after burnishing I dye the edges and apply a sealer such as Wyo-sheen to the edge to seal it. I don't like to use Edge Kote because in some instances it has a tendency to crack. Bob Parks has a short tutorial on finishing edges which is really great. Look it up on line, I think you will enjoy it. Quote Share this post Link to post Share on other sites
Tpc Report post Posted September 17, 2016 Hi, Thanks for the information really appreciate it. What a great site. Quote Share this post Link to post Share on other sites
