Now I know there been a few posts on holes but I may be blind, or not seen one on the buckles with the pegs that have a little ball on the end. From what I can see is there are 2 main type belts. Ones with tongues (common in stores) and ones with the studs that go into the hole. The ones with the studs in turn have 2 type. A hook and a ball.  What type of hole would I make for the one with the ball? A circular with a small cut in the side?
No. Not with a slot. It is best to use a hole that fits a little tightly with the ball. If the leg that the ball is on the end of angles back a fair way they are not to big a problem but if straight, make the hole quite tight.
YouTube Channel
Instagram
