Members justken Posted November 25, 2016 Members Report Posted November 25, 2016 (edited) looking for general info on a Singer 47-66....How thick will it sew?...Heaviest thread it can handle..Will be using to sew two layers of nylon to 5oz suede...what's a machine that's just been gone thru,set up on a flat table, with clutch motor worth? Edited November 25, 2016 by justken Quote
Members Constabulary Posted November 25, 2016 Members Report Posted November 25, 2016 I think it is not as heavy as the 153. I would guess 5-6mm thickness. it is not a walking foot machine. It has a jump foot system if I remember correctly. These were mainly used as binding machines afaik and for lighter leather work I guess Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted November 25, 2016 Members Report Posted November 25, 2016 just found this: http://www.industrialsewmachine.com/webdoc1/used/used-brochures/47w66.htm Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members justken Posted November 25, 2016 Author Members Report Posted November 25, 2016 Thank you sir!... Did a quick search but didn't find much on this machine... Know where there's one for sale, not sure if it'll work for what I'm needing though... Was hoping this machine could handle up to 138 top thread and go thru 3/16(5mm) ... Trying to find out before making a hour drive to go look at it!... Quote
Members Constabulary Posted November 25, 2016 Members Report Posted November 25, 2016 I guess it has the same hook as the 153 though I´m not sure. In case it has the same hook it most likely can handle 138. So I would go and test sew the machine. The seller should not have a problem with that. Needle system is 128x3 so a 22 needle should suit the 138 thread. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members justken Posted November 25, 2016 Author Members Report Posted November 25, 2016 (edited) Thanks again!... Lady has it set up with 69 now... Rarely ever use that small of thread... Just expanded shop and have room for yet another machine!... Guess I'm getting lazy in my young age, tired of having to change needles and tread... Looking at getting a machine for a single process during production runs... My Chief Financial Adviser ( Wife) is sure questioning why I need machine #7 though!... Lol Edited November 25, 2016 by justken Add Quote
Members Constabulary Posted November 25, 2016 Members Report Posted November 25, 2016 if it is not too expensive - why not - I would make the trip and test it. I also have machines (just the heads) that I'm barely using. So what - they don´t eat bread and just need some oiling from time to time Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted November 25, 2016 Moderator Report Posted November 25, 2016 I read the specs of that machine, via Constabulary's link, and saw that its longest stitch length is only 8 to the inch. That will work okay with #69 thread (#16 or #18 needle), but not #138 (#22 or 23 needle). Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members justken Posted November 25, 2016 Author Members Report Posted November 25, 2016 Thank you sirs!... Mr Wizcraft, that's what I seen also... Leaning towards passing on this one... Will share lady's post for others on here though... If allowable.. Ohio Facebook site: Albany/Athens buy sell giveaway.. Quote
Members Constabulary Posted November 25, 2016 Members Report Posted November 25, 2016 right - haven´t noticed the stitch length so 138 thread does not make sense! Sorry! Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
