Hi, just thought I'd ask and see if anyone happens to have a pattern for an iwb holster along the lines of an alien gear, or crossbreed type of holster that would be suitable for "tucking" a dress shirt for a ruger sr9c. All leather, no kydex.
Thanks for any help
  • 4 weeks later...
If all you want is an Alien gear type holster, . . . piece of cake.
1.  Cut a rectangle of leather, . . . 8 oz or so, . . . about 6 inches long and 4 inches wide.
2.  Cut a second one to match the first.  Wet it right real good, . . . and hand form it over your gun, . . . everything forward of the rear sight.  Angle it somewhat so you don't form it over the grip.
3.  Let it dry, . . .
4.  Use a drywall knife to cut out the basic outline of the weapon, . . . look at pictures on the internet so see that you are cutting yours like others have done.  Be sure to leave about 1 good inch on either side.
5.  Rivet the two pieces together.
6.  Add Tandy belt holster clips, one at each end.
7.  Dye and finish, . . . wear.
May God bless,
Dwight
www.dwightsgunleather.com
