Members snubbyfan Posted December 21, 2016 Members Report Posted December 21, 2016 Glueing the front and back of a smooth leather lined pancake holster. Pretty basic stuff here: Quote Keep on Chooglin'Check out my YouTube Channel, comment and subscribe for updateshttps://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
Members TinkerTailor Posted December 21, 2016 Members Report Posted December 21, 2016 On 12/20/2016 at 6:24 AM, CaptQuirk said: @Widget- My Mom's family was from Wilmington, I remember going through Nwark as a kid! Back on topic, I just use the brush that comes in the can of contact cement. The only tip I have, is to wipe the excess globs off the brush, and brush from the center out past the edges. This helps keep the brush from hitting the edge with glue, less clean up before burnishing the edge. I hate that brush. When the can is full, i spent so much time scraping the excess off the shaft above the brush to prevent drools and drips that i gave up and cut the brush off. Along with the pallette knives i suggested above, I also still use the same acid brushes Dwight recommends for bigger areas, and belts especially. The acid brush attached to the lid of the can is way too much of a sticky booger mess for me. It either drips on the project or you hold it brush up and fill the cap of the can with glue...Since i started cutting the brushes off, and using disposables, i have had no problems with the caps gluing on, as I am not dripping glue on the threads while scraping the brush shaft and filling the cap holding it upright. Btw, I rub the threads of new glue cans and lids with a little paraffin wax to prevent the glue from sticking to them. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members CaptQuirk Posted December 21, 2016 Members Report Posted December 21, 2016 @TinkerTailor- That last part was a neat tip. As far as the globs on the shaft, I really don't think about it. I just scrape it along the inside edge when I wipe the brush to get rid of the excess. Just like when I tip the dye jar on my sponge, I now do it AWAY from the leather I'm working on, in case it spills out. Things you learn to do and not to do. Quote
Members YinTx Posted December 22, 2016 Members Report Posted December 22, 2016 Also, on not causing the threads from the can lid from seizing up over time, I read somewhere here on LW to smear vaseline on them, so I tried it. Works like a charm! Haven't had a stuck lid since. I've been using chip brushes, and smearing with an appropriately sized piece of stiff veg tan leather... working so far... YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members YinTx Posted December 22, 2016 Members Report Posted December 22, 2016 Also had one of these Pro-Cement Jars, worked well until I didn't have it anymore. You can replace the head of the brush, the whole brush, adjust it up and down so the rod doesn't sit in the adhesive, seemed to seal well, etc. http://stleather.com/2015-p38.html YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members thekid77 Posted December 23, 2016 Members Report Posted December 23, 2016 In addition to thw other members fantastic suggestions I like the red tandy glue spreaders....you can cover a large or small area quickly and with great control....you will also waste less contact cement and get a more even coat Quote
Members Sluggo001 Posted December 23, 2016 Members Report Posted December 23, 2016 I put my contact cement in craft store plastic squeeze bottles. It will eventually dry out more in the bottle, but it gives great control. You would think the solvents would eat the plastic...it doesn't. Ditto on the plastic glue spreaders. Quote Actually...it is rocket science.
Members Brianm77 Posted January 9, 2017 Members Report Posted January 9, 2017 (edited) I found some metal spatulas in the model car dept at hobby lobby or somewhere for small to medium areas. Larger areas flux brush. Spatula cleans pretty easy with paint thinner or mineral sprits on a paper towel. I have not tried to clean one of them brushes yet. I work with wood wood also and have started using an old deck of playing cards for a lot of things to include spreading wood glue, should also work with contact cement and then you can toss it, I often cut the cards in half. Edit - the thing I don't like about those brushes in the bottle, they always feel like it is fixing to fall off. I now buy cement in a pint size paint type can so don't have a brush anyway. Edited January 9, 2017 by Brianm77 Addition Quote
