Matt, . . . just a little suggestion, . . . put the pencil away for a while.
Literally use yellow manila folders to wrap around the gun, . . .or lay on top of the gun, . . . force it down around the weapon, . . . then get out the masking tape and scissors.
Cut off the "excess", . . . tape back on where you took off too much, . . . re-cut, . . . keep playing with it until you can see laying on your workbench, . . . a reasonable prototype of what you want.
Then use that prototype for the first "pattern".  Cut out a sample of the main body from belly leather, . . . or boat seat vinyl from JoAnn fabric (it's great for quick patterns, . . . and about 10% the price of leather).
That is how you learn to make patterns.  Trying to sit down and draw it from scratch, . . . kinda like trying to do an M1A Abram's tank with a Lincoln welder.
May God bless,
Dwight
www.dwightsgunleather.com
Thanks Dwight. When I have a pattern to go from. It all makes sense. When I'm trying to come up with one it's like Greek written in Chinese characters. Lol
1 hour ago, Mattsbagger said:
I tried drawing up a pattern like the VM 2 or Dwight's Cactus. I just plain and simple can't draw. So what I did was take your G27 pattern Jeff and cut it at the stitch line add 1/2 inch and put it back together. Front side only. It feels pretty good so far I'm used to appendix carry so it a little different for me. Will get a few more pics wI think it on and get up too.
Okay, lost me again :o  Took me a minute to follow that :blush:
If you "stretched" the front panel, that would explain why the gun is so far from the stitch line.
Couple comments --
I like cardboard for making patterns like Dwight is describing.  Manila envelopes (which is where most of us start, since we've been told that) don't allow for thickness, and belly leather stretches too much to be very accurate (though it does allow for thickness).  But a regular piece of corrugated cardboard (the 'honeycomb' stuff shipping boxes are made from) work well for that.  Kinda roll it and flex it until it's softened up some, and then works okay.
Personally, I usually just sketch on graph paper, and when I know I'm 'close', I make one from the same leather I'm going to be using for holsters.  If it isn't quite "right", I'm out less than $10... which I'd pay just to not to have to go get the cardboard :rofl:
Graph paper, because if I like the design, but maybe it could move in or out "right in there" for about 1/8", tehn I just move the line over 1/2 of the 1/4" square on teh paper.. and vee oh la.  And then I often keep a scan of it (because something ALWAYS happens to the original).  Comes in handy when you find that the G19 is the SAME as the G17, but about 12mm shorter (each end).  So just bring up the scan of the 17, re-draw the bottom 2 squares higher, and there's yer 19 ;)
As for "adding to the front".... coming soon ...
Oh, yeah .. 5-6 stitch to the inch is about what I like for 2 layers of 8 oz.
Edited by JLSleather
5 leather patterns
I glued and stitched one side then glued and stitched the other side. It leaves a "pouch". The gun is TIGHT in the holster. Probably add a reinforcement on the mouth next go around but it doesn't collapse now. Stitch lines were left in same place as your original. There was just extra leather between the lines. It seems to help it wrap around more.
See, there's where I got lost.  If you added material, then the stitch lines can't be in the "same place".. they would be further apart.  I know what I think you meant :o but if there's 1/2" more leather, then the fit can't be the same.
HEre's what I did with the G43... make it 'wrap', and if you've seen that video with the airbrush then you've seen me making a "pouch" ;)
5 leather patterns
