Members Windrider30 Posted December 29, 2016 Members Report Posted December 29, 2016 Ok found this pattern some where, think it might have been off tandy's leather library and got bored enough to play around with it, I need to widen the design a little to make it fit my Samsung galaxy S5 other then that came out pretty good, only problem is the liner so maybe one of you can help me, when I stitched it all together the liner bubbled on me a fair bit, its easy to smooth it out when you jam something in to it (currently have my stanly knife in it just because I can lol) I did glue and stitch the whole liner in as one piece, and glued the hell out of it, to stop this from happening would I be better off NOT gluing all of the liner and just glue the outer edges or instead of one whole piece make it to pieces and leave the middle part uncovered? http://imgur.com/gallery/UHhqU (being lazy and do not want to resave and resize the photos lol) Quote
RockyAussie Posted December 30, 2016 Report Posted December 30, 2016 Neat project Windrider30. When gluing in the liner on something that has to come all the way over when finished, it is best to attach with at least a 90 degree or more bend. Attach half then push it down over an edge of a bench or table then flip it over and press out the other half. Normally easiest to have the liner a bit oversize and trim up all the excess after. Note a softer liner would of helped as well. Regards Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Windrider30 Posted December 30, 2016 Author Members Report Posted December 30, 2016 46 minutes ago, RockyAussie said: Neat project Windrider30. When gluing in the liner on something that has to come all the way over when finished, it is best to attach with at least a 90 degree or more bend. Attach half then push it down over an edge of a bench or table then flip it over and press out the other half. Normally easiest to have the liner a bit oversize and trim up all the excess after. Note a softer liner would of helped as well. Regards Brian Thanks for that wife suggested a thinner liner might fix the issue as well will try that with the next one right now using the holster to hold my Stanley knife lol Quote
