Members Tugadude Posted January 19, 2017 Members Report Posted January 19, 2017 21 hours ago, billybopp said: I haven't tried pricking wheels, only overstitch wheels to mark spacing. Mostly because I have only found pricking wheels in pretty high SPI. Whether pricking wheel or overtitch they don't give you any guidance on angle - which is where I seem to need the most help. What I'd really like to try is the VB type pricking wheel which leaves a pricking iron like mark, but they're pretty darn expensive. Bill Actually pricking wheels do help with the angle. They are angled tines and when you use them, they leave distinctly angled impressions in the leather. Quote
Members Tugadude Posted January 19, 2017 Members Report Posted January 19, 2017 I borrowed this pic off of the web. Tells the story pretty well. Quote
Members billybopp Posted January 19, 2017 Members Report Posted January 19, 2017 Thanks Tugadude! That's what I was referring to as a VB style pricking wheel. I've also seen other devices called pricking wheels that are more like a very pointy overstitch wheel - which wouldn't be of much use for me. I'd love one day to try the VB pricking wheel that has an edge guide - that looks very useful, if pricey. I find the angled marks of a pricking iron used with a broad-tipped awl to be best for me. If you hold the awl just a bit loosely when entering the slit it will settle in and give the perfect angle every time - although you still need to be closeish with the angle and that's where a flat sided awl haft as Madmax mentioned helps. It still requires attention to get the awl straight in the horizontal and vertical plane (pitch and yaw in flying terms) - but help with the "roll" angle from the angled slits is one less thing to worry about. Bill Quote
Members Brianm77 Posted January 25, 2017 Members Report Posted January 25, 2017 (edited) I bought these off of amazon. They come in a set of 4, less than $20. I know they are cheap, but just starting out I didn't want to spend a bunch. They have turned out to be well worth the little I spent on em. They will need to be cleaned before use. They are pretty sharp. The one thing I didn't want was for the prong to be tapered all the way up. These have a point then do not tape anymore after that. I like em enough that I went back and bought another size --edit-- the pic did not paste. They are Aiskaer brand. Come in a plastic case. Edited January 25, 2017 by Brianm77 Quote
bikermutt07 Posted January 26, 2017 Report Posted January 26, 2017 3 hours ago, Brianm77 said: I bought these off of amazon. They come in a set of 4, less than $20. I know they are cheap, but just starting out I didn't want to spend a bunch. They have turned out to be well worth the little I spent on em. They will need to be cleaned before use. They are pretty sharp. The one thing I didn't want was for the prong to be tapered all the way up. These have a point then do not tape anymore after that. I like em enough that I went back and bought another size --edit-- the pic did not paste. They are Aiskaer brand. Come in a plastic case. I use the co link brand of those chisel and I'm really happy with them. Need to get around to getting another size of them. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
