How long did it take you to make? Not bad for starting off.
Edited by Tholek
This took me roughly a week to make because of school. But it's also due to inexperience in sewing. Thank you.
Good start. To straighten out your stitching get an overstitch wheel or stitching chisels. Use a compass/dividers set at 1/8th or 3mm(or so) to mark a line from the edge then use stitching wheel or chisel. A fork will work in a pinch.lol. Rule of thumb is about 8 spi on something that size. I use .08 thread.
You're doing fine. When you can pick up some sand paper and a wing divider.
The sandpaper will even up your edges and then you can run your wing divider down a straight edge. This will help you straighten out your stitches a little more.
Just remember to take your time. Get intimate with the edges and stitching. I will pull out a magnifier if I need to. It will make all the difference.
Keep up the good work and keep having fun.
Agrred with the mention of a wing divider and sand paper just a tip though with the sand paper well two yips first always go in the same direction never just back and forth second tip get wet dry sand paper and two size grits i use 60 to start with then jumps to 120 or so then after sanding burnish the edges a bit
Is that mm or inches? That size Tiger is about .023".
You think 1 mm for 4mm chisels, Matt?
Don't have any 4mm. So don't know how it would look. Only one way to find out is to try it and see if you like it.lol That's how I found out I didn't like 1mm thread in 3mm stitching irons.
