Members MikeC5 Posted January 21, 2017 Members Report Posted January 21, 2017 I'm looking for a replacement v-belt for my 111W155 and am not sure what type of belt it is (3L, 4L ?). It measures 0.4" wide and 0.25" thick, numbers which do not exactly match up with 3L or 4L (3L is closer). The only markings I see on it are the brand (Mitsubishi), M-42 and 150P Japan. I'm guessing this may be a metric belt (No. 13 is 10mm x 8 mm), which is closer. Anyone have any recommendation on a belt that will work but is readily available? Quote
Members brmax Posted January 21, 2017 Members Report Posted January 21, 2017 Many times I have found them at ace hardware, and the 3L is what works for me. The style of belt is measured in inch increments usually so your m42 is 42" in measure of the outside. Floyd Quote
Moderator Wizcrafts Posted January 21, 2017 Moderator Report Posted January 21, 2017 Use type 3L v-belts for industrial sewing machines and their pulleys. they are 3/8 inch or 10mm across the top. As already noted, these v-belts are sold by length in inches, not millimeters. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members GPaudler Posted January 22, 2017 Members Report Posted January 22, 2017 I really like twist-lock style v-belts like this, at Mcmaster-Carr. https://www.mcmaster.com/#6173k36/=160yn99 They aren't cheap, but they are easily adjustable, which de-criticalizes measurement and provides flexibility should you change pulleys or mounting. Sometimes one can find a good deal on Amazon. A very knowledgeable and meticulous friend of mine uses one to drive the alternator on his airplane's Lycoming O-360. Here's one on my 105. I already had the other belt and the speed-reduction scheme accommodates a wide range of sizes. Quote
Members dikman Posted January 23, 2017 Members Report Posted January 23, 2017 " de-criticalizes "?? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members GPaudler Posted January 23, 2017 Members Report Posted January 23, 2017 Yup, looks like I wasted a hyphen. Quote
