The problem with Biothane is that it is religious and heals the holes instantly, just before the knots are pulled up. I had better luck sewing Biothane on a Union Lockstitch than on my CB4500 or a Cobra Class 4.
Posted IMHO, by Wiz
  • Replies 27
  • Created
  • Last Reply
Top Posters In This Topic
After messing with the tension I had it sewing perfect. Then when I went to use it today I was having problems with it in reverse.
When I start my leashes, I start it in reverse, sew 3 stitches and then sew forward.  Well today the bottoms of the rev/forward look like spaghetti on the bottom.  It's also now skipping stitches i.e. On the 3rd stitch in reverse I go past the bottom dead center and go forward.  It just skips the last stitch and leaves me with a hole where the needle went in.  This also happens when doing a turn.  The needle goes in, then I go past BCD and turn.  The thread just pulls out and skips the last stitch.
Could this be a timing issue?
Edited by Parott1
Make sure the hook pics up the loop before changing direction. May have to bring the needle up a quarter inch on the up swing before this happens (sounds like ya were doing this)
Also check the allen head bolts thru the access port where the reverse/stitch lever is (not too tight or the handle will be very hard to move). Ive also found the one in the access plate below the lever may need tightening as well.
It still happens on mine occasionally but is reduced.
Edited by MADMAX22
Not sure if this can be of any help in diagnosing the problem,  but I did a few test pieces just sewing backwards.  The machine skips a stitch every 3-4 one.  The underside also looks very sloppy.  Bobbin thread loose and not pulled tight to the material
Edited by Parott1
The machine appears to be in time. I'm using silicon lube that I got from Ryan Neal
