So I was inspired by StormCrow's post about making a splattered wallet, to try out some marbling.
So these were just some scrap pieces I had lying about.  Full of scars and blemishes.  I experimented with some suminagashi inks.  I sealed them with super shene because it seems to make the color more vibrant.  The blue green one on the right is only half covered with supershene (not sure if you can notice in these pics).  The yellow and purple one was an oops because I actually dyed the wrong side of the leather. LOL
I think there is a lot of potential here.  I did a tiny bit of stamping and carving on the left hand one to see if it would screw it up in any way.  Took the tools just fine although it is only 3 to 4 ounce leather.
Check out my Unique Marketing Strategy and see if it might also work for you to get paid for your art.
Super cool looking!
These look much better.
I made some more today and began working on a simple wallet.  I'll throw up pics of that once It's done.  I have never perfected my stitching and prefer to lace.  So, I decided to put these pieces for sale in my Etsy shop for those that are better at making smalls than I am :)
You used suminagashi inks? Have you noticed any bleeding or rub off or anything?
I'm curious how leather dye will work in place of suminagashi inks. I'll have to try it. Did you do anything to prepare the water? I know you don't do anything Hing to the water with suminagashi but you do with European marbling. Just curious about the process. Looks super cool
I tried fiebings leather dye first.  Seems like it should have worked because it is alcohol based, but it didn't work for me.  So yes, I used suminagshi inks on top of straight water.  I have not experienced any rub off, but I have found is that using oil after these inks is not good.  It tends to fade the color.  Sealing it with resolene or super shene works quite well though.  It really is a fun little project.
Awesome thanks. One more question. How did you float the inks? With a brush or dropper or something else?
I bought some sumi brushes and used those.  Just need a brush that holds a good deal of ink.  Having the pointed tip like the Asian ones do, helps also.
Ah I see. I'll definitely have to try this thanks for the info
