Members arz Posted June 21, 2017 Author Members Report Posted June 21, 2017 @Trox Thanks again. I'm comfortable doing this. I did some research and it seems to be a common thing to do. This 220V machine uses 750W total. So they are not large motors. Now I just need to fine a controller that is around $50-100 All the local ones seem expensive. Setting up a business is expensive so I'm trying to save everywhere I can! Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
480volt Posted June 21, 2017 Report Posted June 21, 2017 If the machine can't be rewired to a different voltage, you may be able to use a buck-boost transformer in front of it. Quote
Members arz Posted June 30, 2017 Author Members Report Posted June 30, 2017 I found a different Ellegi (Atom) model and bought it. It was much less than the other one, I only paid $250 for it! This one is newer (2001), a little better condition, was already converted to 220V, and was used by a older couple closing their shoe making shop. Works great. It has a vacuum but not a continuous running knife. For the price I paid I can easily add a second small servo motor to run the feed wheel. At the moment it is in the back of my van until I can find help to move it (it weighs 113kg!). I'll post a photo once I get it in the shop. Thank you for all your help and advice! -Adam Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
RockyAussie Posted June 30, 2017 Report Posted June 30, 2017 5 hours ago, arz said: For the price I paid I can easily add a second small servo motor to run the feed wheel. I think you may mean the knife continuously? The blade always running at full speed works best. Sounds like a very good pick up for the price anyway. Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members arz Posted June 30, 2017 Author Members Report Posted June 30, 2017 1 minute ago, RockyAussie said: I think you may mean the knife continuously? The blade always running at full speed works best. Sounds like a very good pick up for the price anyway. Brian I will use the clutch motor currently on the machine to run the blade continuously (at full speed). I would like to remove the belt from the main shaft to the feed wheel and add a small servo motor for the feed wheel. That will give me great control with feeding. My thought was it will be much easier to do this than add a vacuum Plus for what I paid I could not go wrong. -Adam Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
RockyAussie Posted June 30, 2017 Report Posted June 30, 2017 Ah Ha now I understand. That would probably be easier and I look forward to seeing or hearing how it works out. I'd give you hand to get it out but it's a little bit too far away. best regards Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members arz Posted June 30, 2017 Author Members Report Posted June 30, 2017 Just now, RockyAussie said: I'd give you hand to get it out but it's a little bit too far away. best regards Brian Thank you anyway, very kind of you! If/when I do any modifications etc. I will start a new post. Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members robinindustry Posted June 30, 2017 Members Report Posted June 30, 2017 On 2017/4/18 at 2:15 PM, arz said: Hello, I need a skiving machine (bell skiver) for splitting wallets back, thinning pockets etc,. I need it so I can line a wallet, so I have to get it down to below 1mm. Here in Europe it seems common to do that. I would be using it for 2-3oz (1mm) goat, calf and veg-tan. Maximum 2mm thick. My question is do I need a dual speed set-up? In other words, a constant knife speed and a variable feed wheel speed. The price difference can be almost twice. I have heard some say that you need the blade running at high speeds, but I also need control. Any thoughts on this? Thanks! Adam Chinese Leather Skving Machine......hope can help you :-) This is the link: http://robinindustry.com/product/334.html Quote Best Regards Robin ROBIN INDUSTRY CO.,LIMITED www.robinindustry.com
