Members AnthonyF14 Posted May 8, 2017 Members Report Posted May 8, 2017 Hello everyone. I have really enjoyed reading and learning over the last month from all of you hear. I really enjoyed Wizcrafts sewing machine-101 post. I am looking for a machine that will so leather upholstery for aviation interiors. I am not ready to go for a consew $1200 to $1500 machine yet and I think I will pretty much be strait stiching. I am looking for something close by me here in Virginia Beach and on craigslist I saw these adds over the last weekend but not sure. So just looking for some advice and also alternatives prior to going to the $1200 range in a year or so. I will be working with leather about 0.9mm to 1.5mm mostly. Thank you! https://richmond.craigslist.org/for/6103690557.html https://eastnc.craigslist.org/for/6116640686.html https://richmond.craigslist.org/for/6093145119.html Quote
Moderator Wizcrafts Posted May 8, 2017 Moderator Report Posted May 8, 2017 None of the above are really suitable for leather upholstery. You should refocus your search to find a compound feed walking foot upholstery sewing machine. Did you know about the new Consew Premier P1206RB? It sells for just under a thousand dollars. If you can find one at a dealer within driving distance you can save the shipping cost (~$150 to $200). Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members AnthonyF14 Posted May 8, 2017 Author Members Report Posted May 8, 2017 Thanks Wiz, that's exactly the advice I was looking for Quote
mikesc Posted May 9, 2017 Report Posted May 9, 2017 You sure about those thicknessess ? That is about the mm count I use for lambskin or goatskin "clubwear"..in chrome tan. Lingerie uses thinner for some items, I have some 0.5 mm within arms reach as I type, which I'm cutting and making into "control samples", ( before sending them away to have the first production run of those items made ) this week, the garment cow and buffalo we work with ranges from around 1.0 to 1.5 mm at the thinnest up to around 3 mm. Of course straps , belts, restraints etc of various sorts are often made using heavier again. I've never taken any of the leather upholstery apart on any of the vehicles I have owned to see how thick the leather was, and if I start picking the leather sofa apart at this time of night my wife is not going to be amused, but I would have thought that anything that you sit on ( unless it was leather shorts :) would have to be made using heavier leather than around 1.0 to 1.5 mm.. Intrigued ..what kind of leather at that "thinness" do you use for aviation upholstery ? Have I been sitting on leather that is much thinner than I thought it was..although I did jump out of a lot of aviation over the years..maybe it was the seats :) Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Moderator Wizcrafts Posted May 9, 2017 Moderator Report Posted May 9, 2017 4 hours ago, AnthonyF14 said: Thanks Wiz, that's exactly the advice I was looking for My answers are based on your statement that you want a machine that can sew between 1/2 and 3/4 of an inch of leather. Ounce-wise, that corresponds to 32 to 48 ounces leather thickness. If this is correct, do nothing. If not, correct the unit of measurement and I will recalculate the machine lineup. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members AnthonyF14 Posted May 9, 2017 Author Members Report Posted May 9, 2017 Thanks Wiz. Last night I did some more research on FAA standards and I also talked to folks at Townsend Leather who are a big supplier to a lot of the aviation interior folks. From what I am told and what I read is that the norm is 1.0 to 1.5mm and looking at their conversion chart that comes out to be 2 1/2 to 3 ounces per square foot. I have attached the one bulletin they shared with me. http://www.townsendleather.com/wp-content/uploads/2013/12/Bulletin-6_Thickness.pdf Quote
Members AnthonyF14 Posted May 9, 2017 Author Members Report Posted May 9, 2017 Wiz, is this an older model 206RB? https://norfolk.craigslist.org/app/6089650631.html Quote
CowboyBob Posted May 9, 2017 Report Posted May 9, 2017 No,that's a portable Consew,it has feed dogs & feet w/teeth that will mark + it isn't the type of machine you would want to use for eceryday sewing. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted May 9, 2017 Moderator Report Posted May 9, 2017 4 hours ago, AnthonyF14 said: Thanks Wiz. Last night I did some more research on FAA standards and I also talked to folks at Townsend Leather who are a big supplier to a lot of the aviation interior folks. From what I am told and what I read is that the norm is 1.0 to 1.5mm and looking at their conversion chart that comes out to be 2 1/2 to 3 ounces per square foot. I have attached the one bulletin they shared with me. http://www.townsendleather.com/wp-content/uploads/2013/12/Bulletin-6_Thickness.pdf These thicknesses are totally different than the ones you stated in your original post. They are in fact magnitudes apart! You won't need a 441, 205 or any other harness stitcher to sew soft, thin leather like in the link you posted. These machines will eat that leather. You should probably contact a dealer to see what they can recommend. Based on your new information, I'm leaning towards a Consew Premier P1206RB. It is all you'll need for sewing from about 4 ounces (1/16") up to about 24 ounces (3/8"). Good luck Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members AnthonyF14 Posted May 9, 2017 Author Members Report Posted May 9, 2017 Wiz, man am I glad I posted here and talked to you. Copy all. Yeah, to me I see the numbers and I think they are all the same. I just found a good supplier out of Tampa who I was going to call today so I will ask that very question. I will keep you posted. 1 hour ago, Wizcrafts said: These thicknesses are totally different than the ones you stated in your original post. They are in fact magnitudes apart! You won't need a 441, 205 or any other harness stitcher to sew soft, thin leather like in the link you posted. These machines will eat that leather. You should probably contact a dealer to see what they can recommend. Based on your new information, I'm leaning towards a Consew Premier P1206RB. It is all you'll need for sewing from about 4 ounces (1/16") up to about 24 ounces (3/8"). Good luck Quote
