Members Windrider30 Posted May 30, 2017 Members Report Posted May 30, 2017 Ok so how thick should the core be of a rolled handle or is there no real "right" thickness? Right now I have a 2 inch handle that I am working on (which will drop to one inch when hand stitched together) I figured an inch to half an inch thick might be enough was just wondering. Oh using paracord guts for the core on this handle was thinking of using a leather core but wasn't sure if that would work to well. Quote
Members Stetson912 Posted May 31, 2017 Members Report Posted May 31, 2017 Leather would work ok. Paracord I think would be a bit flimsier? Idk. I'm not sure there is a rule how thick to make it. Do you have Stohlman's books on case making? There's a good section on handles in there that may help. Also, if you want a leather core, if you have how to make whips by Ron Edwards he shows how to make a leather core for a whip which could be adapted to your handle. Hope that gives an idea for you. I've never done it so, just spitballin here. Quote
Members Windrider30 Posted May 31, 2017 Author Members Report Posted May 31, 2017 4 hours ago, Stetson912 said: Leather would work ok. Paracord I think would be a bit flimsier? Idk. I'm not sure there is a rule how thick to make it. Do you have Stohlman's books on case making? There's a good section on handles in there that may help. Also, if you want a leather core, if you have how to make whips by Ron Edwards he shows how to make a leather core for a whip which could be adapted to your handle. Hope that gives an idea for you. I've never done it so, just spitballin here. I have made a few paracord whips so I am firmilar with how to make a whip core out of leather good idea on that thanks will give that a go and see how it works! Quote
Members Stetson912 Posted May 31, 2017 Members Report Posted May 31, 2017 Cool.looking forward to seeing how it works out Quote
RockyAussie Posted May 31, 2017 Report Posted May 31, 2017 The size would depend on the bag size and weight etc a bit but I mostly use some 10mm cord like in the picture here. I make the pattern where the stitch line up wider to start and trim down after I stitch. Self taught and there may be better ways. Here are some pics that may help some.Sorry I have not some more of the break down. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Windrider30 Posted June 1, 2017 Author Members Report Posted June 1, 2017 1 hour ago, RockyAussie said: The size would depend on the bag size and weight etc a bit but I mostly use some 10mm cord like in the picture here. I make the pattern where the stitch line up wider to start and trim down after I stitch. Self taught and there may be better ways. Here are some pics that may help some.Sorry I have not some more of the break down. Great looking bags and thanks, I have some soft cording that I am going to try first, if that does not stop the issue of wrinkling I am going to make a leather core and see how that works out as well! Quote
RockyAussie Posted June 1, 2017 Report Posted June 1, 2017 I should have thought to mention that you will get better results by putting an isolation fabric around the rope first with no glue touching the rope except at the ends. Then you can glue it in place in the leather without losing the free movement of the rope inside. It makes the handles more easily move and stay in place better. Regards Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Windrider30 Posted June 1, 2017 Author Members Report Posted June 1, 2017 I had not thought of gluingin place my first handle just the thread is keeping the core in place but then again handle is only half and inch wide Quote
RockyAussie Posted June 1, 2017 Report Posted June 1, 2017 With some leathers that might work OK I'm not sure.I tend to put an isolator fabric on a lot of leather particularly croc to keep it from stretching around and losing shape as you work it. A lot of keeping the shape and movement of the product is better with an isolator fabric backing the leather where it rubs against another piece. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Windrider30 Posted June 2, 2017 Author Members Report Posted June 2, 2017 8 hours ago, RockyAussie said: With some leathers that might work OK I'm not sure.I tend to put an isolator fabric on a lot of leather particularly croc to keep it from stretching around and losing shape as you work it. A lot of keeping the shape and movement of the product is better with an isolator fabric backing the leather where it rubs against another piece. haven't had the chance to work with croc really want to but cant find a supplier here in Australia...odd I know but most of the croc farms are selling their stuff or are already owned by the major big brands like lewy and all those high end companies Quote
