 Howdy all,  looking for a metal loop like this that will fit through a bag slut in a flap with a strap that goes through it as a closure. I only have this flat metal one as an example, I need some made of round stock with flat ends, to be riveted to a bag.
If anyone can help with what they're called and/or a place to buy I'd be very happy.
Edited by timesofplenty
This is strictly an observation. I don't like the end of a strap "hanging" from a fixture. They get caught on everything plus I feel they look unfinished.
A clever leather loop with some little decorative flourish will hold that strap better.
Ferg
Try looking on ebay for 'eye plate marine fittings'. A quick look came up with these-
http://www.ebay.co.uk/itm/4Pcs-5mm-Stainless-Wire-Eye-Straps-Saddle-Clip-Boat-Marine-Plate-Staple-Ring-/112411348764?hash=item1a2c3d0f1c:g:CssAAOSwjL5ZHYAl
http://www.ebay.co.uk/itm/Pad-Eye-Plate-9mm-x-100m-x-32mm-Stainless-Steel-316-Marine-Grade-No-Rusting-/140313509263?hash=item20ab563d8f:g:xuEAAOSwf-VWY4JH
I'm sure Canadian ebay will have something similar. I don't know if they have a name wen used in leatherwork- 'Staple' maybe?
I think what you are looking for are called footman loops  http://www.brettunsvillage.com/trunks/howto/parts/endcaps/ . Round ones are at bottom of page. All so ebay has a bunch.
Edited by JD62
One day at a time my friends
              John
Thanks, @JD62, that's close! Footmans loops are surface-mount, meant to screw into a solid surface, the ones I'm looking for are thinner and taller.  The flattened ends are much thinner, and th metal rod fits into a bag punch slot, or pokes thru a slit with holes punched at the ends.
HMMM, interesting I don't think Ive seen that but Ill keep looking:crazy:
              John
