The reason why there is little information out there and no aftermarket support is that the whole production run of ASE #9s was about 400 units, followed by 60 Classics made by Tony Luberto. I recently acquired a #9 and assumed I'd just machine a left and right toe foot out of solid at some point. Wouldn't have to be elaborate as it's just a jump foot. Moderator Art has a #9, if he has the left and right toe feet, maybe he would post a photo.
I had a #9 machine, I kept the # 6 and sold the #9...  It did not run as good as the pearson.
 I had all attachments for it. Left and right feet as well as the standard toe. So could sew close to the side without any problem. I can not remember the set up of attaching the feet but i would think it would be pretty easy to get one made up. Take the foot you have to a machine shop in town and ask them to make up one. In calgary,there is a machinist that i have used and can make up all parts for machines i have needed in past.
I've never had the opportunity to talk to someone who had had both a #9 and a Pearson. What advantages does the Pearson have?
Now that I'm home, this is a front view of the standard foot. Looks like it would be straightforward to machine a new mounting plate to shift the foot to the left or right.
6 hours ago, MikeG said:
Thanks - that is probably the best overall solution. I really was just wondering if I was missing something or doing something wrong.  it is certainly not beyond my capability to make a new foot,  I just need to get out there and do it.  Appreciating all the responses and encouragement.  Love this forum!
Just a word of caution, when removing or making a foot right or left be sure to leave a bit in the middle behind the needle and remove back more if needed. If you remove too much you will find the needle can want to climb up the side a bit and leave needle marks on the side. I made that mistake before. I took back one a bit too far for stitching the rope filled round handles and had a lot of trouble keeping it from climbing up the rope. Rope type handle in picture below and note the trimming happens after the stitching . Regards Brian
YouTube Channel
Instagram
The ideas on different feet make total sense now.  Brian, thanks for the tip to keep from making needle marks.  I totally would have missed that.  Since it is a jump foot machine, I still might have an issue with the foot climbing up the edge.  I will keep that in mind and do a follow up on this thread once I have made up some alternate feet.
    Pearson is a much smoother machine, #9 sounds like a tractor when running, Way louder, more"jerky" than the pearson. The only limitation of the #6 is the shuttle system if you want to sew things that need to drop down when sewing by the needle. Which is why had picked up the #9. The machining was not as nice as it could of been. I think #9 is not a "bad" machine but because of the more "clunk" as sewing ,i think the parts will wear out due to the stress put on them when running. If the machining and design could of been slightly tweaked,then i think it would be a awesome machine to run.....
 Sold the 9 and got a bull instead. Much smoother running than the #9.
