Members Chayse Posted July 8, 2017 Members Report Posted July 8, 2017 The title says it all and I couldn't resist! Overall it is in good cosmetic condition and seems to have been looked after properly. It is worn, like so many these days, only gets 8 SPI...oh well, I mainly bought it to save it and to one day use it for it's intended purpose. Nothing time and money can't fix, right!!! Plans are to disassemble, clean, oil, order parts to get the SPI back to as close to normal as I can...then use it ...within it's limits. The only part I see missing is the spring for the darning tension disk...I just may have and extra that might work! I do have a pair of boots that I need to fix, so that might be it's first project! Might touch up the treadle a bit to make it look better and fab up a flatbed table for it. Overall, just keep it looking as it does now...given that this one dates to 1962, it isn't THAT old! I will post a picture later of the contents of the drawer...I should never run out of needles!! Just a quick glance, I counted over 60 29-4 needles, new in their little envelopes...and even more in other packaging. Just thought I would share! Quote
Members Chayse Posted July 8, 2017 Author Members Report Posted July 8, 2017 Treadle...which I sewed with before removing the machine head from the stand. Love these old machines!!! Quote
Members Constabulary Posted July 8, 2017 Members Report Posted July 8, 2017 29K71 are more or lest the most modern machines of this type - beside CLAES patchers - you almost find any part of it as after market part since the Chinese copied this machine almost 1:1 (with some small exception). I have restored a 29K71 in even worse condition a few years back. Manual and detailed parts list are available. Its worth the restoration and it is no big deal, these machines are easy to work with. I got my parts from College Sewing in the UK but most parts are avail. on Ebay or most known sewing machine dealers. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Chayse Posted July 8, 2017 Author Members Report Posted July 8, 2017 I have already downloaded the manual and parts lists, usually the first thing that I do and have read your resto thread on your machine...turned out very nice! I will look on the 'bay' but hard to know if any of the 'new' parts are going to fit without some sort of finaggling...might just be trial and error. I would have to check to see what shipping would be from across the pond...if it is reasonable, then may do it. Hopefully one of the vendors on here may have the parts. I will start with replacing the bell crank lever (part #82167), which is usually the culprit but understandably, it could be a combination of things leading to poor stitch length. Once I get it torn down, I will have a better understanding of what needs to be replaced. Thanks for the insight Constabulary! Quote
Members dikman Posted July 8, 2017 Members Report Posted July 8, 2017 Very nice, on the face of it looks to be in very good condition overall. You've done well. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Chayse Posted July 9, 2017 Author Members Report Posted July 9, 2017 @dikman..thanks...seems in good condition overall, I would think normal use through the years...definitely not one of these we see that is just a pile of rust...missing half the parts. Seller relayed it was a family members machine...found in a shed! Oddly, the only rust is wear the leather belt sat on the pulleys for so long and a bit on the treadle..flat surface for things to settle. Overall, am pleased to own it! I was thinking of painting it but the more I look at it, the original paint is in good condition, so will keep it as is... Quote
Members Chayse Posted July 9, 2017 Author Members Report Posted July 9, 2017 Contents of the drawer...I was mistaken..most of the needles are 29x3...sizes ranging from 120 to 180. Couple bobbins and odds and ends. I will identify the other needles...there are probably 25-30 that are loose. I have no idea if the little oil can is original...nothing that says Singer on it...only a patent date of 1885. Couple screwdrivers and an extra handle for the hand wheel.... Quote
Members Chayse Posted July 9, 2017 Author Members Report Posted July 9, 2017 I have absolutely no idea what the large awl type tool is in the top left...is sharp tho! I think some of the fun is finding what, if any, hidden treasures might be stowed away in the drawer! Quote
Members dikman Posted July 9, 2017 Members Report Posted July 9, 2017 Paint it? Heck, it's in far better condition paint-wise than all of my used machines! I'd leave it like that (unless you want to change the colour). That little wooden needle holder looks OLD!. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted July 9, 2017 Members Report Posted July 9, 2017 (edited) I have restored a few other patchers already with parts from College Sewing. They all worked well I only had to modify the Bell Crank Lever when I installed it in different 29K models. Oh - the set screw for the revolving head di not fit as it came with a metric thread but that was no big issue - re-threaded it with an M5 thread - done. I would probably "touch up" the decal area and put a new decal on - just for optical reasons. Paint looks like hammertone silver. Edited July 9, 2017 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
