Members ContactCement Posted July 21, 2017 Members Report Posted July 21, 2017 Affordable quality leather edger right out of the box. When placing the order I knew very little about the manufacturer or how well they would perform. These were reduced and had limited quantities under $10 each with free shipping. The listed or advertised measurements or specifications for the bevelers is accurate. I think some manufacturers have different specifications or ideas about what a defines their #1, #2 or #3 This #2 is much smaller than another #2 I purchased. Material:High carbon steel + solid wood. 135mm,(5.31") long. Manufacture process: Quenching treatment. Sharp and smooth. No.1 comes with 0.8mm wide bevel, works better for 1.0-2.0mm thick leather (thin) No.2 comes with 1.0mm wide bevel,works better for 1.75-2.65mm thick leather (medium) N0.3 comes with 1.2mm wide bevel, works better for 2.2-3.2mm thick leather (thick) The metal sounds like its tempered (just like other tools in my wood shop) when gently flicking it with a fingernail. The edge beveler does in fact cut veg tan leather right out of the box. The edge beveler arrived faster than expected. The cardboard box described was inside 2 bubble mailers. The edge beveler has a clear tubing to protect the cutting edge and was inside a mini zip lock bag, then packaged in a foam lined rectangular cardboard box with the brand name on it. Quote
Members JD62 Posted July 23, 2017 Members Report Posted July 23, 2017 ????? Brand name, pics, ordering info????? Quote One day at a time my friends John
Members LumpenDoodle2 Posted July 23, 2017 Members Report Posted July 23, 2017 Ditto. Quote “Equality? Political correctness gone mad, I tell you, gone mad!!!! Next they'll be wanting the vote!!!!! “. Anger and intolerance are the enemy of correct understanding
Members Sanch Posted July 24, 2017 Members Report Posted July 24, 2017 On 7/21/2017 at 7:51 PM, ContactCement said: Affordable quality leather edger right out of the box. When placing the order I knew very little about the manufacturer or how well they would perform. These were reduced and had limited quantities under $10 each with free shipping. The listed or advertised measurements or specifications for the bevelers is accurate. I think some manufacturers have different specifications or ideas about what a defines their #1, #2 or #3 This #2 is much smaller than another #2 I purchased. Material:High carbon steel + solid wood. 135mm,(5.31") long. Manufacture process: Quenching treatment. Sharp and smooth. No.1 comes with 0.8mm wide bevel, works better for 1.0-2.0mm thick leather (thin) No.2 comes with 1.0mm wide bevel,works better for 1.75-2.65mm thick leather (medium) N0.3 comes with 1.2mm wide bevel, works better for 2.2-3.2mm thick leather (thick) The metal sounds like its tempered (just like other tools in my wood shop) when gently flicking it with a fingernail. The edge beveler does in fact cut veg tan leather right out of the box. The edge beveler arrived faster than expected. The cardboard box described was inside 2 bubble mailers. The edge beveler has a clear tubing to protect the cutting edge and was inside a mini zip lock bag, then packaged in a foam lined rectangular cardboard box with the brand name on it. Expand Soooo... where did you acquire them? What name brand are they? And I am sure they are probably from China? EBay Maybe? Quote
Members ContactCement Posted July 24, 2017 Author Members Report Posted July 24, 2017 (edited) Here's the link. http://www.ebay.com/itm/Wuta-Leather-Edge-Beveler-Edge-Skiving-Tools-Belt-Makers-High-Carbon-Steel-/152609445287?var=&hash=item23883b55a7:m:mjJUQWMYjVohDQCJcKDwltQ https://en.wikipedia.org/wiki/Carbon_steel Edited July 24, 2017 by ContactCement Quote
bikermutt07 Posted July 24, 2017 Report Posted July 24, 2017 Yeah, I like Wuta stuff. Haven't tried these yet though. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
