Members Leahlovesleather Posted August 1, 2017 Members Report Posted August 1, 2017 I want to buy a skiver. I am using a safety beveller from Tandy and want something that is not disposable and holds its sharpness longer. Hobby Tools in Australia have this wood knife https://www.hobbytools.com.au/kirschen-carving-knive-with-long-wide-blade-skewed-edge/. Does anyone think it would be good for skiving? Has anyone used a ceramic blade? Sounds like they stay sharp longer but take a lot of effort to sharpen. Any thoughts welcome. Quote
Members Instinctive Posted August 2, 2017 Members Report Posted August 2, 2017 I have a similar knife that is meant to be a wood carving knife. It is Japanese steel and razor sharp (with honing). Cuts leather like butter. Assuming the steel is good, it is worth a try. You might want to look to see if there is a specialty store that focuses on high quality wood working tools. They may have higher quality tools for only marginally more money. I paid $32 CDN for mine. Quote Eric Fisher Fisher Custom Leather "A Retirement Project" https://fishercustomleather.wordpress.com/
garypl Posted August 2, 2017 Report Posted August 2, 2017 I use a Japanese marking knife to skive - it's about 1/2" wide and is as sharp as a scalpel. I bought it years ago in Japan for woodworking - suppose you could buy something similar at any good woodworking tool supplier. Quote Cowboy 4500, Consew 206RB-4
Members Leahlovesleather Posted August 3, 2017 Author Members Report Posted August 3, 2017 Thank you for the comments. I found one locally, similar to garypl's and will have a look at it today. Cheers, Leah Quote
Members Leahlovesleather Posted August 3, 2017 Author Members Report Posted August 3, 2017 This is what I bought. The angle is very strep but I an gring that out a bit over time. Similar Japanese metal to yours garypl. Quote
Mark842 Posted August 3, 2017 Report Posted August 3, 2017 I use a head knife for skiving. I've used knives with blades shape as the one you show and they work good if the blade is good. A lot of it depends on what you are skiving and how wide you need to the skive to be. For most things I've found a good head knife to be more versatile for this as you can do wide and thin skives were as the knife your looking at will only give you a path as wide as the blade. Quote
Members Leahlovesleather Posted August 3, 2017 Author Members Report Posted August 3, 2017 (edited) I'm uprised you could understand a bloody word I said! I have turned auto text off in my settings, and I am starting to think it was a mistake. Head knives might be something I invest in later on. They look a bit scary. Edited August 3, 2017 by Leahlovesleather Quote
garypl Posted August 3, 2017 Report Posted August 3, 2017 2 hours ago, Leahlovesleather said: This is what I bought. The angle is very strep but I an gring that out a bit over time. Similar Japanese metal to yours garypl. Did you try to post a picture? I don't see what type knife you bought. 1 hour ago, Mark842 said: I use a head knife for skiving. I've used knives with blades shape as the one you show and they work good if the blade is good. A lot of it depends on what you are skiving and how wide you need to the skive to be. For most things I've found a good head knife to be more versatile for this as you can do wide and thin skives were as the knife your looking at will only give you a path as wide as the blade. You are right Mark - the thin blade I am using works best for small areas like wallet card holder edges. Would definitely be more work trying to get an even skive on larger areas. I have a round knife I bought from Tandy, but I need to sharpen it a lot more to get it to skive cleanly. Been thinking about investing in a better quality knife. What brand head knife do you use? Quote Cowboy 4500, Consew 206RB-4
Members Leahlovesleather Posted August 4, 2017 Author Members Report Posted August 4, 2017 Don't know what happened there. I don't have a head knife as I have only been interested in leatherwork for a few months. , They look a bot serious for me at this early stage and from what i have learnt, you should invest in a good one. This is the knife I bought: hopefully it loaded. Quote
Mark842 Posted August 4, 2017 Report Posted August 4, 2017 9 hours ago, garypl said: Did you try to post a picture? I don't see what type knife you bought. You are right Mark - the thin blade I am using works best for small areas like wallet card holder edges. Would definitely be more work trying to get an even skive on larger areas. I have a round knife I bought from Tandy, but I need to sharpen it a lot more to get it to skive cleanly. Been thinking about investing in a better quality knife. What brand head knife do you use? I have an assortment of old ones..mostly osbornes. Just get yourself a good stone and practice sharpening it. Once you get a good edge it's easy to keep with regular maintenance. Quote
