No problem Rockoboy, . . . a little hijack never hurt anyone.
Yes, indeed, you can use it again, . . . and again, . . . and again.  I have plastic quart bottles that I keep my "made up" dye in, . . . just take off the lid, . . . pour it in the pan, . . . do the dying process, . . . pour the rest back into the bottle, . . . put the lid back on and set it back up on the shelf.  I then just wipe out the pan with paper towels, . . . put it back up on the shelf for the next one.
When I did the work above, . . . I made up another 16 oz of dye (2 ea 4 oz bottles of dye and 2 ea 4 oz bottles of reducer), . . . added it to the pan before I started, . . . when I got done, poured the rest back into the bottle.  If I calculated correctly, I think I used about 14 oz of dye mix to do two holsters, a dress belt, gun belt, and the assorted straps for the shoulder holster.
May God bless,
Dwight
Edited by Dwight
www.dwightsgunleather.com
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
Great looking outfit and great looking holsters!!!
Thanks so much!!
Real craftsmanship, Dwight...and I'll echo the sentiments of a few others...that saddle tan looks great!  Thanks as always for sharing your knowledge & methods on the dip dyeing technique.  I've been re-vamping my own methods as of late and have considered utilizing dip dyeing, especially for some of my products where contrasting thread isn't requested by the customer...you've been a big help. Thanks!
Have a great day!
Chris
Double Daddy, . . . I made my commitment to dip dying several years ago, . . . just got fed up with the sponging, wiping, etc, that sometimes did OK, . . . sometimes looked like something that needed a grave under the garbage heap.
Messed with an air sprayer, . . . did not like the lack of depth, . . . it is only a surface coating.
Jumped in with both feet on the dip dying, . . . and again, . . . fooled around with other reducers, . . . finally decided that since Feibings makes the dye, . . . they probably make the better reducer, . . . so all of my dye is reduced 1:1, . . . before it is used.
And as you touched on the subject, . . . the only hangup is when someone wants a contrasting thread.  Fortunately, . . . I don't see that much, . . . and you won't hear me complain about not seeing it either.
May God bless,
Dwight
Okay...since I apparently have you close by. My customer base varies slightly from your'n a bit in that they like the contrasting thread...about 60/40, contrasting/matching. My question to you: do you use only white thread in your sewing machine and just baptize the entire thing in dye in the course of construction, per order...or do you go thru the process of changing out the thread to true brown/black/etc, per order?  I know that, in the past, when I have dyed white thread to match the surrounding leather, it has dried a slightly lighter color than its "true thread' counterpart (factory black, brown, etc)...but not enough so to be visually off-putting. Swapping out thread in my machine isn't a big deal...bobbins stay pre-wound in my work room and I can do it in a quick-minute...just wondering how others handle workflow.
Edited by Double Daddy
Have a great day!
Chris
Hey Waldo,
Thanks for sharing - as always.  Two item I might add, though.  First off, when I dip-dye, I use a plastic tub to dip in, as all thing metal grate against my preferences.  Note how metal contacting wet leather will leave a dark stain, so why chance it on finished work.  Secondly, I have found that Everclear, which NOBODY drinks any more (I sincerely hope) make a great reducer - and much less expensive.  When I mix, I recover as much excess dye as possible, and label to mixture for further use.  1/5, 1/3, etc.  Saves a lot of dye.
Wellllll, . . . actually, I use all white thread, . . . but I do have a small spool of black.  Never have had anyone want anything but black or white, . . . and probably would discourage them if they did want some off the wall combination (red thread on a green holster).
The few I get ask for the white stitching, . . . so it really is just a matter of when do I stitch, . . . before or after dying.
AND, . . . my machine is a Tippmann Boss, . . . which just every now and again can be a pain when I change out the thread.  Never figured out why, . . . just know it happens, . . . I sometimes think my machine is a female, . . . it can get peeved over the slightest nothing, . . . and takes it out with a vengeance.
And, yes, . . . the white thread does come out a tad less dyed than the leather, . . . even the black, . . . but it is close enough that I've never had a customer get all up in arms about it.
He probably wouldn't be a customer long if he did, . . . because it is just that close.  I'd give him his money back, . . . bid him adieu, . . . put the item on Ebay, . . . and get my $$$ back.  Also put that dude on a DO NOT CALL list.
May God bless,
Dwight
9 hours ago, cowboycolonel said:
Hey Waldo,
Howdidja know the answer to the question:  Where's Waldo??   That's where Dwight lives.
Seriously, . . . my metal pans are actually an aluminum pan for the browns, . . . and a porcelain (white) pan for my blacks.  Got another aluminum one for odd stuff that I do once in a blue moon.
I've never had any problems with any of them.
Everclear???  Here in Ohio, . . . it is illegal to own, sell, traffic, purchase, or possess.  OTOH, . . . if you know the right "ol' Southern boy", . . . ya might get something that will be in the same neighborhood of 190 proof, . . . and yeah, . . . folks around here still drink it, . . . not me of course, . . . but others do.
May God bless,
Dwight
