Members LeatherWorkerGirl Posted September 21, 2017 Members Report Posted September 21, 2017 I want to know how much Resolene I should apply. I'm using Fiebieng's Neutral Resolene finish and I've read that a thick layer will show bend-spots or cracks. Need advice on this ASAP Quote
garypl Posted September 21, 2017 Report Posted September 21, 2017 I thin Resolene 50/50 with water. I airbrush several coats, but you can also apply thin coats with a brush or damp sponge. Quote Cowboy 4500, Consew 206RB-4
Members LeatherWorkerGirl Posted September 21, 2017 Author Members Report Posted September 21, 2017 So will applying 100% Resolene mess it up or just thick coats? Quote
garypl Posted September 21, 2017 Report Posted September 21, 2017 Thinning the Resolene allows you to apply very thin coats, increasing the likelihood that you will have a durable finish. You could apply it 100%, but there is a greater chance you will create thicker coats that are more likely to crack. From what I have read, just about everyone thins the Resolene and I have always had good results thinning it. Go ahead and experiment - that's half the fun of leatherworking! Quote Cowboy 4500, Consew 206RB-4
Members LeatherWorkerGirl Posted September 21, 2017 Author Members Report Posted September 21, 2017 Alrighty then! Thanks for your help! Quote
Members Dwight Posted September 21, 2017 Members Report Posted September 21, 2017 I've personally never had good results with the full strength stuff. Thin it like garypl said, . . . I brush it on with cheap bristle brushes, . . . love the finish. Usually 2 light coats works for all my belts, holsters, and knife sheaths. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members LeatherWorkerGirl Posted September 21, 2017 Author Members Report Posted September 21, 2017 2 hours ago, Dwight said: I've personally never had good results with the full strength stuff. Thin it like garypl said, . . . I brush it on with cheap bristle brushes, . . . love the finish. Usually 2 light coats works for all my belts, holsters, and knife sheaths. May God bless, Dwight Thank you Dwight, I will try 50/50 on my recent bookmark. Thanks for the tips! Quote
