Members Sorcerer1 Posted September 25, 2017 Members Report Posted September 25, 2017 I have made a couple holsters out of 8/9 oz. leather with good results . I made my own pattern for a "Slim Jim " style . My question is will I need to extend out past my pattern in order to make up for the much thicker 9/10 leather , or am I over thinking this ? Just seems that there will be a difference once it is folded over . Thanks for any feedback / recommendations . Sorcerer1 Arley Quote Hard to believe that my life is based on a true story
JRLeather2 Posted September 25, 2017 Report Posted September 25, 2017 I actually don't think you will see much difference between the two weights..... Quote
Members Sorcerer1 Posted September 25, 2017 Author Members Report Posted September 25, 2017 Thanks a lot . I just wasn't sure. I can not ruin leather as I am on a fixed income and an old fart to boot . Arley Quote Hard to believe that my life is based on a true story
Members OLDNSLOW Posted September 25, 2017 Members Report Posted September 25, 2017 I will probably get yelled at but, with any build you have to account for thickness, if the pattern calls for say 7/8 and you use 8/9 it will end up being very tight. If it is a pattern you created and did so with the weight in mind then you should be ok. but it does make a difference, I have built a few that called for a given weight and then added a liner or thicker leather and didn't move stitch lines accordingly it ended up tight or small for the gun. Quote
Members Sorcerer1 Posted September 25, 2017 Author Members Report Posted September 25, 2017 Thanks to you . I think I will leave some room just in case .I may leave a bit around the trigger guard are also then adjust as needed after the fold . Thanks , Arley Quote Hard to believe that my life is based on a true story
Members Mattsbagger Posted September 25, 2017 Members Report Posted September 25, 2017 (edited) I agree with Ron. The tolerances can run pretty tight and like you said don't want to waste leather.trimming a 1/4 inch off edge is a lot less waste than a square foot or more. Edited September 25, 2017 by Mattsbagger Quote
Members Stetson912 Posted September 25, 2017 Members Report Posted September 25, 2017 Here's a thread and I think there's another one too in the same place, both pinned to the holster and sheath section. It's a very good tutorial and lots of good info. But, it shows how to size the holster using the leather you'll be using for the holster. Quote
