Nice looking saddle Jon.  Clean and neat and well made.  May I add a critique...mostly related to design... skirt shape does not match seat and jockey shapes.  Skirt should have a fuller rear corner to match jockey (or change jockey shape to match skirt).  Side seat jockey is a bit too deep down the side, and a bit too short front to back.  Follow the cantle line around the seat jockey and back thru the front of the swell.  This is cosmetic, and wont affect the functionality of the saddle.
Keith Seidel
Seidel's Saddlery
www.seidelsaddlery.com
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Thanks for the comment Keith I appreciate your taking the time to critique it. Look at it now I see what you are saying about the front to back line on the side jockey and I will take that into account on the next one. As far as the skirt and jockey or rear housins are concerned I was trying to cover an oversight in my construction and evidently I missed the mark.  I needed to cover the top of the rigging and. I tried to blend the rear and bottom lines to do so but the better fix would have been to raise the rear D about 3/4 on an inch
Great looking saddle!
Will serve your customer well and Roughout will only get better with time.  Billy
Yes, raising the rear dee would have been the proper adjustment to maintain the shallower, larger radius of the rear jockey to match the skirt.
Keith Seidel
Seidel's Saddlery
  • 2 weeks later...
you mention that you sew with the cobra 4 and then mention 2 needles would clarify that for me.
thanks
ya I went back and reread the post and it sounds like he buck stiches the horn and it comes out looking like the stich from a cobra 4.
I see there is some confusion about the stitching. I use 277 nylon thead with 2 needles and wax it just like its linen thread. Its a standard lockstich just done with nylon so the look and material is the same as the rest of the saddle. The reference to my cobra 4 is I walk over to the cobra and pull off the amount of thread I need. Hope that clears it up.
