Members mwpdx86 Posted November 11, 2017 Members Report Posted November 11, 2017 I have a Consew P1206RB and it seems to be working for the most part. Occasionally though (like one out of every 3-5 stitches) when running the machine very slowly or with the hand wheel, it seems like the feed dog and the inner foot (the one with the needle going through it) will sort of jam up. Like it turns fine, with almost no resistance, and then right when the foot comes down to meet the feed dog, it freezes up and is very hard or impossible to move/advance. Until recently, I had just been backing it off with the hand wheel a tiny bit, and then stepping on the pedal and that seemed to work usually. But then yesterday, I noticed that when this happens, if I hit the knee lifter just a little, something (I think the feed dog) makes a pretty noticeable 'sproing' sound and then it's easy to turn again. My completely inexperienced, in-my-head diagnosis is that the feed dog is sometimes moving backwards too slowly/quickly/not in sync with the foot and causing a weird jamming and then releasing the pressure with the knee lifter lets it slip back to where it should be and then everything works normally again for a few stitches. No idea if this is possible or whatever, that's just what it seems like feeling/listening to the machine. As far as I know, the machine has been this way since I got it a few months ago. I haven't used it a ton and I'm hoping I haven't been messing it up somehow by using it like this. Quote
CowboyBob Posted November 11, 2017 Report Posted November 11, 2017 Have you taken the end cover (over the needlebar) & lubed every pivot point you can see there's at least 14 or more spots that need some lube once a month.Even oil @ the top & bottom of the needlebar & the pressure bar where it runs through the casting & the nut on top. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members mwpdx86 Posted November 11, 2017 Author Members Report Posted November 11, 2017 Not yet but I can try. I was under the impression that this was mostly a self oiling machine (apart from some of the walking foot mechanisms in back) but I can get in there and see what it looks like at least. Quote
Members brmax Posted November 11, 2017 Members Report Posted November 11, 2017 (edited) Here can be some tips on pages 3 with points of lubrication, and sometimes others only people as Bob or Gregg may know about having seen the insides of these beast. Anyway good luck Floyd http://www.consew.com/Files/112347/InstructionManuals/P1206RB.pdf Edited November 11, 2017 by brmax Quote
CowboyBob Posted November 11, 2017 Report Posted November 11, 2017 The main bearings & upper feed parts are the only parts that are automatically oiled. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members mwpdx86 Posted November 12, 2017 Author Members Report Posted November 12, 2017 I've lubed all the parts that look lubeable, and it still seems to lock up intermittently. I've examined it a bit more too and when I release the tension via the knee lift, both the foot and the feed dog snap upwards (not back/forth as I had originally thought). Quote
Members mwpdx86 Posted November 12, 2017 Author Members Report Posted November 12, 2017 Also, and this may be completely unrelated, the stitch length knob won't go smaller than three. The smaller I go, the tighter it feels and can't seem to get it to go past #3. Quote
Members brmax Posted November 12, 2017 Members Report Posted November 12, 2017 Its possible the feed dog is loose, if im understanding your description. Its normally a slow continuous movement. May have to remove the motor belt, threads and feed dog cover and carefully get a better view if possible. With the stitch knob is there a spec on stitch per inch, or how is it referred in the book. Some machines refer differently, by that 3 per inch is a long stitch. Good day Floyd Quote
Moderator Wizcrafts Posted November 12, 2017 Moderator Report Posted November 12, 2017 Feed dogs are usually only held onto the fork with two very small machine screws. The pressure exerted by the presser foot/feet on the feed dogs can loosen them over time. The higher the foot pressure, the more likely they are to loosen up and move out of specs. Tightening feed dog screws can be a challenge. I keep a very long (10"), narrow blade, big handle screwdriver for working on both the throat plate and feeder screws. I find it best to remove the faceplate from the head in order to get the best possible angle on the feeder screws. If the feed dog screws are allowing it to move around, tighten them as much as possible. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
CowboyBob Posted November 12, 2017 Report Posted November 12, 2017 On 11/12/2017 at 2:10 AM, mwpdx86 said: Also, and this may be completely unrelated, the stitch length knob won't go smaller than three. The smaller I go, the tighter it feels and can't seem to get it to go past #3. Expand Do you know if you push on the reverse handle when you make your stitches shorter it relieves the pressure off of the knob . Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
