Guest Debbie Posted December 10, 2017 Report Posted December 10, 2017 Hi, hope somebody can help me. I have a singer 331K4. I've been using it with no problems at all since I purchased it around 12 yrs ago. I use it for my business so it gets a lot of use but nothing too heavy. The stitching is perfect but the top thread is coming through with a rust colour on the thread. I use white mainly and it's wedding items I am making so this is not good. I cannot seem to find out either online or from repair people what is wrong with it. Any ideas? Quote
Northmount Posted December 10, 2017 Report Posted December 10, 2017 @Wizcrafts, in case you missed this. Debbie, Are your tension disks clean? Tom Quote
Moderator Wizcrafts Posted December 10, 2017 Moderator Report Posted December 10, 2017 Debbie; Sorry for being late to notice this post. I play music on the weekends and don't get to sleep before 3 or 4 am. Your thread must be picking up rust off something along the way, between the thread spool and the needle. Start troubleshooting by unthreading and inspecting the thread itself. If good, move along as follows, inspecting each piece of metal for rust. Check the thread guide on the thread stand Check the top post if you thread through it. Inspect the three hole thread guide before the top tension disks. Unscrew the tension nut and remove the top tension spring, opener and disks. Chances are this is where you'll find rust and maybe even grooving from long term usage. If the disks are okay, run a length of white thread through the check spring assembly (under the top tension disks). If that assembly isn't the cause of the rust, it's better left alone. The next item to inspect is the take-up lever. Run clean thread back and forth and see if it picks up rust (hope not). After that, look at the few thread guides going down, then the last guide on the needle bar. Last, check the needle for a rusty eye! If you find a part that is rusted, and it is easily replaced (e.g., top tension disks or thread guides), replace it. If it is in a difficult location, try using rust remover where it is rusting. If the hole in the take-up lever is the culprit, have a dealer replace it for you, unless you care to undertake a very difficult task. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted December 10, 2017 Moderator Report Posted December 10, 2017 I just looked at a picture of a Singer 331k4 and see that the check spring is simply attached to the same shaft as the tension disks. The spring itself could be rusting. It is not too hard to replace with a screw driver and some smarts. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Mark842 Posted February 2, 2018 Report Posted February 2, 2018 Just another thought on this if you have not figured it out... is your thread getting oil on it? Quote
Guest Lee Posted May 24, 2024 Report Posted May 24, 2024 Hi all. Yesterday I bought a 331K4 here in France and it has terrible tension and making loads of loops on the bottom, so top tension. I'm having the hardest time trying to find the correct parts to service her with a new tension dial and perhaps new feeddogs, solid pressor foot and plate and maybe a roller foot for doing cutves. Could anyone help as to where to find it in EU, not UK as there a lot of import duty attached. I'm getting lost with various parts numbers and between consew and singer and brother as some are interchangeable. I'm so readu to sew with her as I make clothing from old tapestries and none of my other machines can handle it well. .please help! Quote
Northmount Posted May 24, 2024 Report Posted May 24, 2024 On 5/24/2024 at 10:58 AM, Guest Lee said: I bought a 331K4 Expand You should join LW and frequent the Leather Sewing Machine forum. That's where the sewing machine guys hang out and you'll get more help there in general. Every post in Help Wanted has to be approved by a moderator before it becomes visible. Quote
