Making a basic veg tanned belt. Want to use Chicago Screws instead of rivits but they are new to me and I’m not sure what Length post to use. Strap is 9-10 oz and will be skived at buckle end to maybe a bit more that half thickness. Any thoughts? Thanks!
I use the open back they sell at Tandy's :)  They are the smallest posts and when you use the Chicago screws it good to use lock tight on them so the screws don't back out.
Proverbs 90:17
17 And let the beauty of the Lord our God be upon us, And establish the work of our hands for us; Yes, establish the work of our hands.
NKJ
Singer 15/31, Cobra 4, Tacsew T111, and Walmart $80 Singer thingy :)
For 9-10 ounce un-skived, i use 1/4" posts, but since you're skiving it, 3/16" posts should work.
When figuring out what length post to use, remember that 8 ounce leather is about 1/8" thick. Sounds like you are skiving to about 6 ounce thickness.
6 ounce = 3/32".
3/32" x 2 is 3/16".
The leather will compress some if the post is slightly too short, and that's ok. If you go too long, it will slide around, possibly getting caught on pant loops, and the holes might stretch.
Something else to remember when installing chicago screws is to put a dab of thread lock on the threads of the screw. Make sure you use the kind that isn't permanent.
May the Grace and Love of our LORD and Savior Jesus Christ, the Son of God, be with you.
Acts 4:12Nor is there salvation in any other, for there is no other name under heaven given among men by which we must be saved."NKJV
Guess who the first leather worker is! Read Genesis chapter 3, verse 21 ;-)
Tom, thanks for the tip on the thread lock substitute! I don’t plan on using Chicago Screws a lot - so don’t want to buy a tube of thread lock at least right now
8 hours ago, superpacker said:
Jeselright - very helpful formula! Is there any benefit to the open back screws?
Yes, they don't bottom out, letting you cinch down tighter on thinner materials.
Tom
On ‎12‎/‎11‎/‎2017 at 6:07 PM, Northmount said:
Fingernail polish works to lock the threads too.
Tom
Hay, I did not know that :) I'm going to have to try that thank youB)
Proverbs 90:17
NKJ
  • 2 weeks later...
