Members Constabulary Posted February 15, 2021 Author Members Report Posted February 15, 2021 On 2/14/2021 at 5:35 PM, Wizcrafts said: Ach du liebe zeit! Your German is becoming better Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted February 16, 2021 Moderator Report Posted February 16, 2021 9 hours ago, Constabulary said: Your German is becoming better In the early 1970s I lived with a German family for a year. This was the lady's favorite saying. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Patrickthatsme Posted April 22, 2024 Members Report Posted April 22, 2024 @Constabulary well done. just got hold of one of these and very excited. I also have the same issue with a different hook and the bushing being slightly off with the hub. I have removed the bushing set screw but the bushing seems to be seized to the body of the machine... unless I'm missing something? I'm scared of giving it a good whack to free it.. don't want to so thought I'd ask here first in case I'm missing something! is there a groove or lock mechanism for the bushing aside just the one set screw? Cheers. Quote
Members Constabulary Posted April 22, 2024 Author Members Report Posted April 22, 2024 When the bushing is stuck it must likely is gummed up with old oil so I´d try some penetrating oil or kerosene (what ever desolves old oil) and if it does nor help apply heat with a blow torch and then try again. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Patrickthatsme Posted June 29, 2024 Members Report Posted June 29, 2024 Thanks @Constabulary got it going and so happy with the results! I envy your custom binder attachment / swing plate for mounting the attachments as you pictured. any tips on how to mount these? I have been using flat bed binder attachments on a flatbed machine (the type that sit below or "in" the needle plate and sit where the standard feed dogs & presser foot normally would). I would love to mount these on the machine but it seems like I'd have to tap new threaded holes into the 108w20's binder swing plate or do some other mods. curious to see how you attached yours! I've attached a photo of the plate that came with the machine. Quote
