Members Byrd1965 Posted February 6, 2018 Members Report Posted February 6, 2018 First post first question , the spacer leather between the two sides of a holster is called what? New to leather craft no project to show planning on making a holster for my use at range and want to know if the leather in question is glued only or glued and sewn Thanks You K Byrd Quote
Contributing Member fredk Posted February 6, 2018 Contributing Member Report Posted February 6, 2018 A thin [narrow] leather strip which goes between the two main pieces of the leather, along an edge, on a holster, sheath or shoe is called a welt For handiness it can be lightly glued in place and sewn thru when the two main pieces are sewn together. Contact adhesive or double-side tape can be used to hold it in place Quote Al speling misteaks aer all mi own werk..
garypl Posted February 6, 2018 Report Posted February 6, 2018 4 hours ago, Byrd1965 said: First post first question , the spacer leather between the two sides of a holster is called what? New to leather craft no project to show planning on making a holster for my use at range and want to know if the leather in question is glued only or glued and sewn Thanks You K Byrd Welcome K Bird! Definitely sew it - eventually the glue joint will fail from stress of putting a handgun in and out. The glue holds the pieces together while you stitch them together. Gary Quote Cowboy 4500, Consew 206RB-4
Members Dwight Posted February 6, 2018 Members Report Posted February 6, 2018 When you go out to get your glue, . . . make two stops. First one is at a lumber store or hardware store, . . . buy a pint of Weldwood contact cement. https://www.lowes.com/pd/DAP-Weldwood-Off-White-Interior-Exterior-Contact-Cement-Construction-Adhesive-Actual-Net-Contents-32-fl-oz/3819177 Second stop is at Harbor Freight, . . . you want a package of acid brushes, . . . https://www.harborfreight.com/36-pc-12-in-horsehair-bristle-acid-shop-brushes-61880.html Put a light coat of the contact cement on each piece, . . . fully coat the points where they come together, . . . take a hair dryer or heat gun and lightly go over it (need a well ventilated area to do this) to dry out the contact cement. When it is dry to the touch of your fingers, . . . carefully put the two pieces together, . . . and apply pressure. I like to use a wall paper seam roller. Finish off the edge with a sander of some sort. I have two of these, . . . they work great. https://www.harborfreight.com/1-in-x-30-in-belt-sander-61728.html I usually groove the edge for my stitch line. https://www.tandyleather.com/en/product/craftool-adjustable-groover Then finish off by rounding the edge. https://www.tandyleather.com/en/product/craftool-pro-classic-fine-edger Oh, . . . and welcome to the wonderful, . . . enjoyable, . . . sometimes expensive, . . . and addictive, . . . world of leather working. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Byrd1965 Posted February 6, 2018 Author Members Report Posted February 6, 2018 Thank you all for information Quote
